Changing Transmission fluid to ATF 4 from purple colored fluid - JeepForum.com
post #1 of 12 Old 06-30-2013, 12:03 AM Thread Starter
Left_Clicker
Alright so I have my 1996 ZJ with the 4.0 Motor, I did a pan drop of the transmission today and I found that the fluid the PO used was purpleish brown. I know the PO changed the tranny fluid because the pan edges had evidence of being sanded down in an effort to being cleaned and it didn't look as bad as my dad's ford when we did his.
My question is this, I used ATF 4+ which is red, the stuff I collected out of the pan is a completely different color? Is it bad that they were mixed together? what fluid did the PO use?
On another slightly related note, I want to replace my brake fluid, does anyone know if there is a problem with mixing DOT 3 and DOT 4 brake fluid? I'm not sure what is in there because IDK what the PO used.
On the plus side at least PO took good care of the car to do a tranny fluid change
Left_Clicker is offline
post #2 of 12 Old 06-30-2013, 12:26 AM
PolkaPower
Color is not near as important as smell. Change the fluid and move on. As long as both are pre and up to ATF 4 compliant it doesn't matter.
PolkaPower is offline
post #3 of 12 Old 06-30-2013, 12:27 AM
jm8881
I don't know if I've ever seen purple trans fluid. Something was added or the fluid is burnt or something. And it's not royal purple since royal purple is red. All you can really do is drain it and replace it with atf + 4.
Some brake fluids are not compatible, if there is any doubt, just read the brake fluid label. Some of them will say it's compatible with both.
jm8881 is offline
post #4 of 12 Old 06-30-2013, 05:24 AM
Candymancan
I've seen purple fluid before.. My 249 transfercase the fluid was purple when I drain it.. Lol no idea why it was purple.. my guess is it was original and just really old
Candymancan is offline
post #5 of 12 Old 06-30-2013, 08:27 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Royal Purple is purple. Well the engine and diff oil are for sure, haven't seen the trans fluid.
HighLonesome is offline
post #6 of 12 Old 06-30-2013, 10:33 AM
Syncityj
How should it smell?
Syncityj is offline
post #7 of 12 Old 06-30-2013, 10:39 AM
jt_armstrong
1994 ZJ
It should smell sweet. If it smells burnt then for sure it needs changing.
jt_armstrong is offline
post #8 of 12 Old 06-30-2013, 10:39 AM
a70eliminator
It's purple, as is B&M trick shift.
a70eliminator is offline
post #9 of 12 Old 06-30-2013, 10:59 AM
PolkaPower
You would know if it smells burnt. It's awful smelling
post #10 of 12 Old 07-02-2013, 12:32 AM
Evil_98_ZJ
It's purple as well.
Evil_98_ZJ is offline
post #11 of 12 Old 07-02-2013, 01:27 PM
jm8881
I could have sworn we put royal purple in my friends jeep and we expected it to be purple but it was red. This was years ago though.
jm8881 is offline
post #12 of 12 Old 10-13-2013, 07:36 PM
djlarroc
1997 XJ Cherokee
Bumping this thread.. I installed a trans cooler on my jk yesterday.. I was going to drain and fill. I began to drain into a clean jug and the fluid was purple. Not burnt red, straight purple. I thought the previous owner installed royal purple, so I put it back in. I had spilled about half a quart, went to advance and bought 1 quart of royal purple max ATF. It's red like normal trans fluid. Doesn't smell like regular ATF tho..
'97 XJ Country, 3" hybrid, 245/75 MTR, TJ Moabs, Front Truetrac/Rear Aussie, 4:10 gears, skids, recovery.
djlarroc is offline
