Its not hard. There's 2 bolts that hold the housing in. Just make sure you RTV the new gasket on the t-stat housing 1st before putting it back down in that tight space. Then torque it down to 30in lbs.
Yep. A thin bead of Red (high temp) RTV will work wonders. I like to apply the bead, let the housing sit for 10 minutes or so and then bolt the housing back in place. This allows the RTV to cure a little bit.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
