changing steering U Joints - JeepForum.com
post #1 of 6 Old 07-10-2013, 06:44 PM Thread Starter
Mrrell
Im changing my steering U Joints ...but thats not the problem I can handle that ....after I pull out the hubs is there some type of clip in side the diff case that needs to come off before I pull or would they just slide right out ...please help ....this is a back yard job is there any easier way
Mrrell is offline
post #2 of 6 Old 07-10-2013, 06:58 PM
dnuccio
sounds like you are changing the axle u joints, not steering u joints. and no, there is no clips holding the axles in on the front. they just slide out.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 6 Old 07-10-2013, 07:50 PM
AlphaLorde
And there is no need to start multiple threads
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #4 of 6 Old 07-10-2013, 07:51 PM Thread Starter
Mrrell
Great thanks any pointers to look out for ....so that means I dont reall6 have to take over the cover
Mrrell is offline
post #5 of 6 Old 07-10-2013, 08:34 PM Thread Starter
Mrrell
Well excuse me cyclops but it wasnt going thru
Mrrell is offline
post #6 of 6 Old 07-10-2013, 11:02 PM
txbass06
Never messed with the u-joint style axles but I just replaced one of my front cv's so the prices should be almost the same. Only issue I ran into was getting the top hub bolt loose. I'd suggest you spray them down with pb blaster a couple days before you do it to help with that
txbass06 is offline
