Changing interior lights - JeepForum.com
post #1 of 11 Old 03-12-2013, 06:26 PM Thread Starter
KyleD31
Hello, I plan on changing all the interior lights in my 93 zj to LEDs, I have started this and did the ones in the door, but now I don't know how to do the lights under the dash. They seem to be a different bulb. Do I just pull them out or do they unscrew?
KyleD31 is offline
post #2 of 11 Old 03-12-2013, 06:28 PM
xcaliber81
twist and pull, i just put some in lol.just bulbs.
xcaliber81 is offline
post #3 of 11 Old 03-12-2013, 06:34 PM Thread Starter
KyleD31
Ill try it now
KyleD31 is offline
post #4 of 11 Old 03-12-2013, 06:45 PM Thread Starter
KyleD31
Got it, you gotta push up, twist, then pull out. I have the wrong bulbs lol. I need 89s
KyleD31 is offline
post #5 of 11 Old 03-12-2013, 06:57 PM
xcaliber81
Back-up .................................................. ...............1156
Center High Mounted Stop Lamp .......................921
Fog............................................... .............................H3
Front Turn Signal ..........................................1295NA
Front Side Marker ...........................................194NA
Headlamp/Aero.............................................. ....H6054
License Plate .................................................. ........168
Rear/Stop/Tail .................................................. .....2057
Rear Turn Signal .................................................1 156
Underhood Lamp .................................................. .105
INTERIOR LAMPS
Service procedures for most of the lamps in the instrument
panel, are located in Group 8E. Some components
have lamps that can only be serviced by an
Authorized Service Center (ASC) after the component
is removed from the vehicle. Contact local dealer for
location of nearest ASC.
A/C Heater............................................ ..........4720843
Ash Receiver.......................................... ...................37
Cargo Lamp.............................................. ...........212-2
Cigarette Lighter .................................................. ...53
Climate Control........................................... .............74
Console Floor Shifter........................................... ..194
Dome/Reading........................................... ..............561
Door Courtesy .................................................. ......168
Front Reading .................................................. ......906
Glove Compartment....................................... ........194
Hazard Lamp .................................................. .........74
Heater .................................................. ...................194
Overhead Console .................................................. 212
Radio............................................. .........................ASC
Rear Cargo............................................. .................212
Rocker Switch............................................ ...............37
Shift Lamp.............................................. ..................74
Transfer Case Shifter ............................................194
Theft Alarm .................................................. ............74
Under Panel Courtesy.......................................... ...89
Vanity Mirror .................................................6 501966
post #6 of 11 Old 03-12-2013, 06:58 PM
xcaliber81
That's for my 94.
post #7 of 11 Old 03-12-2013, 07:05 PM Thread Starter
KyleD31
That's for my 94.
Thanks! Helps a lot. Where did you buy your lights from? You have LEDs right?
KyleD31 is offline
post #8 of 11 Old 03-12-2013, 07:12 PM
xcaliber81
No led's yet just bulbs. I have that stickied to my desktop so when I get my led's I can quickly look it up. I was referred to http://www.superbrightleds.com/
post #9 of 11 Old 03-12-2013, 07:25 PM Thread Starter
KyleD31
Superbrightleds is where I was looking too. They're just expensive is all lol
KyleD31 is offline
post #10 of 11 Old 03-12-2013, 07:37 PM
xcaliber81
Well consider the little twist in bulbs that go in the cluster I can only get them at mopar and they are 21$ each now that's expensive lol.
post #11 of 11 Old 03-12-2013, 07:45 PM Thread Starter
KyleD31
Haha yeah that's true
KyleD31 is offline
