Changing D30 shafts questions - JeepForum.com
post #1 of 15 Old 03-26-2013, 09:54 PM Thread Starter
Grand_ZJ
So I want to change out my current axle shafts (cv) to some u joint shafts and had a few questions regarding the swap.
I have a 98 limited with a d30 from a 95 zj that had cv's.
Now I hear that if I want to change the shafts I need to worry about the stub shaft lengths to make sure they are the same length, so as not to risk ruining the hub's.
Ive always thought that the shafts were the same length as in any zj, xj and tj d30. Am I wrong in thinking this??
And any particular year of xj axle shafts I should look for as they are stronger then the rest? (I.E. u joints etc etc)
1996 XJ Sport
Grand_ZJ is online now
post #2 of 15 Old 03-27-2013, 07:17 AM
kensnelling
As far as length of the stub shaft they should be the same. The main thing to watch out for is that the tone wheel for the ABS sensors is there (if it;s not from a ZJ aplication).
Ken
kensnelling is offline
post #3 of 15 Old 03-27-2013, 08:24 AM
riot1987
some older xj's have a disco long shaft axle that wouldnt work for a direct swap but I believe from what i have read that you should be okay swaping around shafts. Tj/Zj/(most)Xj d30's use the same guts
Build thread^^
riot1987 is offline
post #4 of 15 Old 03-27-2013, 09:34 AM
Technohead
Unless you are upgrading to alloy shafts I don't see much point swapping out the cv shafts for cardan shafts.
-Eric
Technohead is offline
post #5 of 15 Old 03-27-2013, 11:02 AM Thread Starter
Grand_ZJ
I agree to a point and that being is my shafts are spewing grease and I believe the driver is clicking.
1996 XJ Sport
post #6 of 15 Old 03-27-2013, 03:55 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i've broken a half dozen cv shafts and never even replaced a u-joint for wear. had the u-joints shafts in longer and with much bigger tires.
ratmonkey is offline
post #7 of 15 Old 03-27-2013, 04:23 PM
Zakimations
The D30's axle shafts certainly don't hold up if you like to baja as much as me. Rat knows his stuff about axles though, he is picking out my next one after mine grenades in Moab this weekend.
Zakimations is offline
post #8 of 15 Old 03-27-2013, 05:02 PM
KingtheZJ
i blew up both cv shafts in devils den in 3 minutes with a front locker on 33s. put in ujoint shafts and it was good till i pulled the axle.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #9 of 15 Old 03-27-2013, 07:10 PM
Technohead
I've got at least 10 broken u-joint shafts laying around. All from the last 3 seasons.
If you are doing any serious wheeling then you really need alloys. And its no coincidence that the strongest alloys on the market use CV joints.
The nice thing about the stock cv shafts is that they are dirt cheap.
-Eric
post #10 of 15 Old 03-27-2013, 07:59 PM Thread Starter
Grand_ZJ
I had u joint shafts in my old d30 but when I swapped axles I never put them in as ive been told that they differ from the stub that sticks out of the hub. So if its too long itll screw up your hubs and too short it obviously wont work.
This is just what ive heard from an offroad shop here in vegas. I always thought a d30 is a d30 so theyre the same. Because its interchangeable.
I dont do much extreme offroading but on occasion ill do some rock crawling.
Basically I was wondering if a certain year xj is better. Didnt a certain year(s) xj's have the bigger 760 joints in them???
1996 XJ Sport
post #11 of 15 Old 03-27-2013, 08:18 PM
Technohead
Originally Posted by Grand_ZJ View Post
. . . Basically I was wondering if a certain year xj is better. Didnt a certain year(s) xj's have the bigger 760 joints in them???
They did not come with the 760 joints. I don't even think 760's existed when XJ's were rolling off the assembly line. From 96+ (and possibly earlier) they came with 297x joints which can be replaced with 760 joints.
But the strength of the joint is basically irrelevent for D30 shafts anyway. 99 times out of 100 its the yokes that break.
-Eric
post #12 of 15 Old 03-27-2013, 09:04 PM
riot1987
You used that almost alloy kit from IRO? Wouldnt that help? By yoke do you mean the Ears?
Build thread^^
riot1987 is offline
post #13 of 15 Old 04-29-2013, 11:34 AM
Corrupt
The whole red circled area is the yoke. It's the part that helps extend or shorten your driveshaft when in off camber situations.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #14 of 15 Old 04-29-2013, 07:13 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
while technically correct, they are talking about axle shafts, not drive shafts.
I will say, i have broken 3 CV style shafts, but never a U-joint shaft on larger, more aggressive tires. broke the 3 CV's on only 31's, but ran 33's on u-joints with no issues.
they each have pro's/ cons. If you break a CV, no big loss you can still get home. break a u-joint and you better have a spare, as if it is the yoke ears that break they like to hang up on things while still spinning in the axle.
as for the swap, 97+ XJ have the larger joints.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #15 of 15 Old 04-29-2013, 07:29 PM
speedbucket
As long as you can knock the joint out you can get home with the stub shaft still intact
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
