Changing the allwheel drive to selective 2x4 - JeepForum.com
post #1 of 4 Old 06-04-2004, 02:36 PM Thread Starter
chetzx
Im thinking about buying a jeep grand cherokee. The one i looked at is allwheel drive. I was wondering if there is anything i could do to make it so i can select 2x4 or 4x4. Is there any kits you can buy for this? Or would i need to change the transfer case to make it selective 2x4 4x4.
chetzx is offline
post #2 of 4 Old 06-04-2004, 02:59 PM
Meerkat
You would have to change the transfer case. While this is a fairly popular swap, you may not want to change it out. It really depends on what kind of driving you intend to do. If you are going to be doing mostly on road driving, the Quadra Trac is an absolute gem in the ice and snow. If you are going to be doing mostly offroad, the Select Trac will handle the stress much better.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 4 Old 06-04-2004, 03:02 PM
Buddha_Kip
Buddha_Kip's Avatar
You'll pretty much have to switch your transfer case out to a 242.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #4 of 4 Old 06-04-2004, 03:05 PM Thread Starter
chetzx
I would be doing quite a bit of offroading as well as some burnouts here and there so thats why i want the select-trac option
chetzx is offline
Possible to change 00 wj quadra drive to select drive? Blackdout00wj ZJ Grand Cherokee Forum 17 01-26-2010 07:43 PM
quadra drive with no front drive shaft cloiselle ZJ Grand Cherokee Forum 22 03-21-2009 01:51 AM
Quadra-Drive 4-wheel drive system genislav ronen ZJ Grand Cherokee Forum 0 11-17-2007 12:11 PM
changing yokes for new drive shaft phant0omx ZJ Grand Cherokee Forum 12 04-09-2007 09:41 PM
knocking in drive train/ DRive w/o axle shaft? farmerzj ZJ Grand Cherokee Forum 11 04-03-2007 07:11 PM
