changin the diff fluid in the 44a....and SNAP...SNAP - JeepForum.com
post #1 of 22 Old 09-14-2009, 09:16 PM Thread Starter
zippome
i just broke two more bolts. The top two.:brick wall
now what
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline
post #2 of 22 Old 09-14-2009, 09:21 PM
JrMechanic
Easy Rocky, you need to step away from the torque wrench...
You're lucky it's the top two. There's a good chance you can get by without it leaking.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 22 Old 09-14-2009, 09:26 PM Thread Starter
zippome
i wasnt even turning that hard. all the other ones came out fine. im thinking im going to put it all back together without the top two and see if it leaks. if it doesnt, then great. if it does then it would be a good reason for an 8.8 swap . or ill just drill and retap em
zippome is offline
post #4 of 22 Old 09-14-2009, 09:42 PM
driabyor
driabyor's Avatar
1994 ZJ
Bolts that size , small bolt. small wrench
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #5 of 22 Old 09-14-2009, 09:44 PM
driabyor
driabyor's Avatar
1994 ZJ
use a left handed bit, chances are it will back out as you drill
5.2 liter 242 :)
driabyor is offline
post #6 of 22 Old 09-14-2009, 09:46 PM
CLNinja
CLNinja's Avatar
yeap... left handed bit.. or an EZOUT
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #7 of 22 Old 09-14-2009, 10:04 PM Thread Starter
zippome
hooray! guess whos dropping his gas tank then! oh well, maybe ill cut out the wheel well while im doing that
zippome is offline
post #8 of 22 Old 09-14-2009, 10:11 PM
CLNinja
CLNinja's Avatar
why are you dropping your gas tank for diff cover bolts?
Matt
CLNinja is offline
post #9 of 22 Old 09-14-2009, 10:13 PM
JrMechanic
WJ's have really low gas tanks, I don't think you could access the top bolts with a regular drill. You may be able to jack the back end up and use an angle drill however...
post #10 of 22 Old 09-14-2009, 10:14 PM Thread Starter
zippome
because they are the very top two and there is almost no room to work. dropping the tank isnt that big of a deal. ive been meaning to cutout the spare wheel well anyway. just havent gotten around to it.
zippome is offline
post #11 of 22 Old 09-14-2009, 10:38 PM
Virmagicus
Virmagicus's Avatar
Please make sure you disco the battery. I see how your night is going already.
Jeff
Virmagicus is offline
post #12 of 22 Old 09-14-2009, 11:21 PM
iluvtruenos
Dude, just RTV the **** out of it.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #13 of 22 Old 09-14-2009, 11:37 PM
sadass
Just in case are overlooking this thought. cant you Put a jack under the hitch to lift the body while the axles/tires(diff) stays on the ground. that will open up a clear shot at that diff. tank will raise with the Unibody.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #14 of 22 Old 09-15-2009, 01:00 AM Thread Starter
zippome
oh i did, dont worry
i could... or i could work a little bit more and have an extra 8" of ground clearance after a few cuts
zippome is offline
post #15 of 22 Old 09-15-2009, 02:02 AM
sandman
i bet it wont leak if you leave it.
1993 Jeep ZJ. 4.0
sandman is offline
hard reverse snap intrevic ZJ Grand Cherokee Forum 10 10-12-2009 03:48 PM
Can anyone snap a 4.0 pic? WiCkeDuDe ZJ Grand Cherokee Forum 4 09-19-2009 06:48 PM
Huge Snap Noise lawdogg ZJ Grand Cherokee Forum 6 11-10-2006 07:11 PM
snap, crackle, POP!? pu_guru ZJ Grand Cherokee Forum 1 06-08-2006 12:42 PM
Snap! ats1968 ZJ Grand Cherokee Forum 2 01-22-2005 11:12 AM
