Quantcast Changed diff fluid, now jerking! - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Changed diff fluid, now jerking!
Old 12-15-2007, 11:20 PM   #31
greasefingers
1994 ZJ
For what it worth: I have only used regular gear oil, not synthetic, in the diffs. With over 200k miles I have had to rebuild the front diff. I change both diffs fluid every 30k miles since the day it was driven off the lot. Maybe I should have started with synthetic?
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 12-15-2007, 11:23 PM   #32
Windowsrookie
The manual says to put synthetic in the rear diff if you have the tow package (which I do) I plan on changing the oil completely this summer (not just pumping it out) so will the dino + Friction Modifier be good until then or will it screw up the LSD?
And I'll check codes in the morning it's dark and scary out now.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline   Reply With Quote
Old 12-16-2007, 12:28 AM   #33
Trouble Maker
Trouble Maker's Avatar
No problem with dino and the FM.
Easier to see the flashes in the dark.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline   Reply With Quote
Old 12-16-2007, 02:27 AM   #34
ratmonkey
Living dead mod
ratmonkey's Avatar
I have the towing package, and a V8. So I would assume it has LSD.
the tow package is 3.73 gears, class IV hitch, and tranny cooler. the LSD is only an option, and not a common one at that.
ratmonkey is offline   Reply With Quote
Glock Forum
