#1 | |
Changed diff fluid, now jerking!
Ok, just a half hour ago I sucked out the old diff fluid in the front and back of my GC (going to pop off the diff covers and change completely this summer). I put 80w90 in the front, and 85w140 in the back. Now I took it for a drive around a couple blocks and it was all good for 2 or 3 blocks. It then started jerking when taking off from stop signs. Then on the hill on the way back there was alot of jerking and the engine killed. I got it started again and brought her home, jerking at the 2 or the stops signs on the way back. What did I do?
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive 1987 Wrangler 4.2L |
#2 |
4.0 Piston Skirt Victim
Its hard to say exactly but if I had to guess something just happened to fail at the time after you did the change. I really have no clue what it is, can you give a more specific description of whats going on, maybe some sounds, feelings, etc.
WALTER |
#3 |
It doesn't seem to be making any sound. Just when leaving stop signs it will jerk and vibrate. Then going down the hill it killed the engine.
#4 |
Does it feel like the brakes are being applied on and off?
WALTER |
#5 |
No, it's not the brakes. It feels like gears slipping.
#6 |
It has nothing to do with the diff oil change but must be something else. How is the transfer case atf level ?
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#7 |
I bought ATF+4 to put in the transfer case but I don't have a big enough wrench to get the drain and fill plugs off. (Gonna borrow one from a friend).
Would lack of friction modifier in the rear diff cause jerking?
#8 | |
WALTER |
#9 |
It's just a vibration feeling until I get up to speed. No harsh bang.
#10 |
Ok, went to move it into the garage and it took a long time to start. Like 20+ seconds. What the hell is going on?
#11 |
check to see if any engine codes were stored.. like a misfire or something.
Mess with anything else while you were under there?
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
#12 | |
#13 |
Anybody? Would the lack of friction modifier cause the vibration? Would the vibration cause the engine to kill?
#14 |
humor us and check the codes..
jerking when accelerating sounds engine related not driveline related unless you making sharp turns
#15 |
I bought friction modifier from the dealership. Do I put the whole 4oz bottle in the rear diff?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
