change your oil filter to nissan - JeepForum.com
post #1 of 3 Old 11-23-2001, 02:02 PM Thread Starter
desert lover
change your oil filer of grand to big size
of nissan (cedric 200l etc why?????
because its bigger. double filteration ,reserve more oil and more cooling thanx
desert lover is offline
post #2 of 3 Old 11-23-2001, 03:42 PM
horatio102
OK, that's all fine and dandy. There's a bypass in the oil filter, in case the filter gets plugged. Does the Nissan filter have the same threshold for bypass?
There are other things to consider when getting your oil filter, not just diameter of the seal and the thread count on the bore.
horatio102 is offline
post #3 of 3 Old 11-24-2001, 08:06 AM Thread Starter
desert lover
actually i am not sure about this bypass
but the other thing its sam thread and oil seal you can test that by removing the seal of nissan and fixing it instead of mopar filter because iam using it now thanks
Change the oil filter? mjonesjr WK Grand Cherokee & XK Commander Forum 9 09-14-2009 05:46 PM
98 zj trans filter change n00blike ZJ Grand Cherokee Forum 9 11-07-2008 09:53 PM
Change your fuel filter! 96grandcherokee ZJ Grand Cherokee Forum 11 06-09-2006 11:28 PM
Filter change in tranny rwild ZJ Grand Cherokee Forum 12 02-23-2006 10:26 PM
Filter Change JeepingOverYou ZJ Grand Cherokee Forum 0 03-04-2005 01:48 PM
