Quantcast Center console inverter install. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Center console inverter install.
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-30-2009, 04:59 PM   #1
Mickey_D
The Great White Ghost
Mickey_D's Avatar
Step one. Find a handy dandy inverter for around $10. One of the ones that plugs into your cigarette lighter socket. Dismantle it so you can access the circuit board inside. Solder new wires onto the power and ground connections and attach them into a handy fog light wiring kit you have lying around (ok, I already had one of these ). Now solder wires onto the 110V connections and put crimp connectors on the ends to attach to a $0.44 wall socket from Walmart.
Now empty all your crap out of the center console.
Remove the two screws from the bottom and three from the hinge of the inner liner of the center console. Pull the inner liner out.
Mark off and cut the holes for the wall socket. A Dremel tool with the drywall hole cutter works wonders. Smooth it up with a sanding drum in the Dremel.
Now make the hole for the switch. Push the switch in, screw in the wall socket, use double sided tape to mount the circuit board to the inside of the console. Run the power wires for the switch and relay up the console so you can tap into the cig lighter socket power lead.
It's a tight fit to get the inner liner of the console back in. I had to pry the front edge a little with a jewelers screwdriver, but it popped back in. A couple of the wires on the switch had to be bent over a little as there's only a little more than 1/2" of space between the outer and inner bits of the console. So standard crimp connectors stick out a little too far, unless they're bent out of the way.
I haven't had a chance to fire it up yet as I got called inside to make coffee. I also was getting quite warm out there in the sun and taking apart a section of the dash to get to the back side of the lighter socket just wasn't thrilling me at the time.
And yes, I'm going to put a cover plate over the socket. Just haven't decided whether I want to find an indoor one that has some camping or four wheeling theme printed on it or whether I want to go all utilitarian and put one of those gray outdoor waterproof flip covers on it.
A big thank you to whomever sponsored my membership!!
1974 CJ-5 258 3spd SOA on 31's [Sold in 1991]
1995 ZJ Limited 5.2 on 31's [Sold in 2009]
1990 XJ Laredo 4.0, nothing special [Sold in 2010]
1955 Willys CJ-5 #12171 [Sold in 2011]
1997 ZJ Limited 5.2 The Great White Ghost
1953 Willys M100 trailer
Mickey_D is offline   Reply With Quote
Old 04-30-2009, 05:21 PM   #2
BLACKzj52
interesting.
and thatll work jsut fine?
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 04-30-2009, 05:47 PM   #3
Mickey_D
Mickey_D's Avatar
It'll power anything under 100W. Cell phone charger, laptop charger, etc. Anything you could charge off of a USB. Which is perfect for my son's Nintendo DS whenever we're on a road trip. Which was the primary purpose behind me putting it in and why it faces the back seat.
It was a royal PITA for him when he had to string the cord all the way up to the cig socket. The cord on his charger was too short so he ended up hunched forward trying to play without pulling it out of the inverter or getting the cord in the way of the shifter, etc. So now he'll be able to sit back in comfort and play without his battery going dead on his game.
For anything more major than what this can handle I've got a Coleman 850W/1300W inverter I'm going to be mounting on the inside of the rear hatch. Just need to save up for the 4 gauge power wire for that one.
Old 04-30-2009, 06:01 PM   #4
5-90
5-90's Avatar
1988 XJ Cherokee
Even the 100W units can get warm - may want to vent that, and possibly a small (1" to 1-1/2") 12VDC muffin fan might not go amiss.
As far the 4AWG - you can hit me backchannel, and I can fix you up with a preterminated lead if you like.
Kelley's Works in Progress - www.kelleyswip.com
KWiP Parts Exchange - www.kelleyswip.com/exchange.html
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote
Old 04-30-2009, 10:15 PM   #5
Rmart30
X2...... even the last cig lighter plugged model I bought came with a fan and it didnt last too long with heavy use.
Rmart30 is offline   Reply With Quote
Old 05-01-2009, 06:32 PM   #6
vansskaterfreek
im planning to do something like this on my jeep, i had it in my old car, and it worked great, i had an x-box 360 in the back seat with a 17 inch t.v laying on the rear seat... fun road trips..
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline   Reply With Quote
Old 05-01-2009, 07:01 PM   #7
Mickey_D
Mickey_D's Avatar
Well, I don't think my little 75W/100W one that's in there would power an xBox and TV. Maybe one of those all-in-one PS1's...
Old 05-01-2009, 08:56 PM   #8
vansskaterfreek
i would also put a cover over it, and i also would have gotten a black plug...
Old 05-05-2009, 08:10 AM   #9
bradbb2005
bradbb2005's Avatar
I just mounted a 1000W inverter on my back seat(small one) on my wj, finding 6 gauge wire isnt fun but i did and pd only 11.00 for like 50 ft! but she is capable to about 750 Watts maybe 800 just due to the limitations on 6 gauge wire cuz @ 750 watts im pushing 63 amps and then max current on 6 guage is like 70-75 A plus connector limit so im thinking im limited to probably 800 watts or just under 70 amps.
My Blog - A work in progress
Autocheck VIN Report for $5.00.
Originally Posted by Bubba3200 View Post
After I drain the oil I started the engine and ran it for a very short while..... to drain some oil out of the filter so it is not so messy.
Click Links to see Pics!
2001 WJ Laredo 4.7L V8
Mods:[]Cold Air Intake[]General Grabber AT2's 245/70-16[]1000W Inverter[]Flowmaster Super 44[]
2005 KJ Renegade 3.7 V6
Mods:[]Firestone Destination A/T's[]
bradbb2005 is offline   Reply With Quote
Old 05-05-2009, 10:01 AM   #10
gregs887
Up your butt Jobu
gregs887's Avatar
Very nice. There was a guy named Matt that did that a few years ago. Been wanting to do the same ever since I saw it. How long did that take you?
Greg
Never underestimate the predictability of stupid- Bullet Tooth Tony
gregs887 is offline   Reply With Quote
Old 05-05-2009, 10:03 AM   #11
aaron7
Cool. I built mine into the dash. No more buying car chargers for everything!
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio (see details)
89 MR2 MK1.5 - Body done, built 450whp 3sgte, 6 year project so far
89 MR2 SC - 317k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going :)
74 CB360 - Lots of cool cafe stuff :D
aaron7 is offline   Reply With Quote
Old 05-05-2009, 04:45 PM   #12
Mickey_D
Mickey_D's Avatar
The longest part was sorting and soldering all the wires up and connecting them to everything.
The actual install into the console it took me longer to get all the tools sorted than it did actually using them. I held a cover plate up as a stencil to mark where to cut, used the Dremel to make the rough cut, held up the socket to see where it needed more trimming then used the Dremel with a sanding drum to make the holes big enough.
I think for me the hardest part was that even on the slowest setting the Dremel was more melting the plastic out of the way than it was actually cutting or sanding it. So I had to keep stopping and letting everything cool enough to continue.
Old 05-05-2009, 06:45 PM   #13
Greengc4x4
Link to said inverter
Greengc4x4 is offline   Reply With Quote
Old 05-05-2009, 08:03 PM   #14
Mickey_D
Mickey_D's Avatar
You can get them in the automotive section at Walmart right by the battery chargers. A basic $10-$15 cigarette lighter socket inverter is all I used.
Old 05-05-2009, 10:47 PM   #15
aaron7
Same here. I used this one: http://www.amazon.com/Black-Decker-100-Watt-Inverter-VEC1044BD/dp/B000EJTHY2
Glock Forum
