Center Console - JeepForum.com
post #1 of 7 Old 03-15-2003, 11:42 PM Thread Starter
automan25
Center Console
I'm thinking of removing the center console to try and gain access to the O2 sensor wiring harness from above. Does anyone know how to remove the center console?
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #2 of 7 Old 03-15-2003, 11:51 PM
bparker
I would like to sit in on this thread as I also would like to know how to remove it..
1996 Black V8 ZJ - Clayton 4-Link LA Kit, RE 4.5" Coils, Procomp MT 33x12.5s, 4.56 gears, Adco sway bars, JKS Discos, PIAAs, B&M Tranny cooler, Tom Woods shaft, U-Joint shafts, JKS F/Track Bar, Kevins RP Sliders, Diff Skid, Protofab F & R bumpers, Bilstein shocks, Mopar Performance PCM, Mike Leach Headers w/ Carsound Cat + Magnaflow Muffler
2002 Black on Black Z06
bparker is offline
post #3 of 7 Old 03-16-2003, 10:31 AM
Swamp Boy
Swamp Boy's Avatar
Chiltons says on 99 and newer models place the shifter in fully rearward position. (1st) and remove the rear storage bins (2 screws) then the front storage bin(2 screws) On the 99 and newer
it will be necesary to pull the cupholder uppwards to access the screws.( There is also a screw under the rear storage bin)
Remove the console from the vehicle by pulling the console up past the shift levers and toward the rear of the vehicle..
If you need pics I can scan the page for you ..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #4 of 7 Old 03-16-2003, 10:38 AM
Swamp Boy
Swamp Boy's Avatar
Here I scanned it just in case..
Copy and paste for a larger image..
Good luck..
post #5 of 7 Old 03-16-2003, 02:40 PM Thread Starter
automan25
Thanks for taking the time SwampBoy, but do you have any info on the '93?
post #6 of 7 Old 03-16-2003, 07:53 PM
Swamp Boy
Swamp Boy's Avatar
The upper image on the same page is for pre 99 which
includes ours (93) and here is the instructions as per
chiltons
Remove the cup holder and put the shifter in neutral
Hold the shifter and give the handle a sharp tug upwards
It. Pry the(PRNDL) plate off Remove the console mounting screws.
Lift the console upwards and disconnect electrical connectors.
Romove the console from the vehicle by pulling it up past the shift
lever and toward the rear of the vehicle..
Another diagram to follow..
Same as before copy and paste for a larger image..
Good luck hope this helps..
post #7 of 7 Old 03-17-2003, 10:50 AM Thread Starter
automan25
Thank you much, that will be very helpful. BTW, when I copy and paste the image, it doesn't get any larger. The Jeep forum server must resize the image when you post it.
Center Console BRayf78 ZJ Grand Cherokee Forum 7 09-13-2009 01:30 AM
Center console cracking? EvilWJ02 ZJ Grand Cherokee Forum 4 07-13-2009 06:38 PM
center console dannyo ZJ Grand Cherokee Forum 1 10-27-2005 05:32 AM
Center Console tray keljeepgirl ZJ Grand Cherokee Forum 1 10-10-2004 05:36 PM
center console ? Skillet ZJ Grand Cherokee Forum 2 04-04-2004 09:09 AM
