CEL: o2 sensor going on and off, what gives? - JeepForum.com
post #1 of 6 Old 05-09-2004, 08:12 PM Thread Starter
4x4 XJ
My CEL came one and I took it to my mechanic to hook up his scanner. It came out as being the o2 sensor. He reset the ECU and called it a day and told me to bring it back if it came on. Well, yesterday we had HUGE storms and all streets were pretty flooded with 2ft of water everywhere. I did have to traverse some of it to get home and here and there, so, the CEL came on and off. Sometimes it would come out, I would hit some water, light went off. My catalytic converter was changed about 2 weeks ago due to it being clogged. This was a cheapo muffler shop new cat, so I think that might of affected it. Anyone have any info?
1997 ZJ Limited 4.0 H.O.
NP242
D30/D35
BFGs
4x4 XJ is offline
post #2 of 6 Old 05-09-2004, 08:29 PM
Meerkat
I would check the watertight integrety of the electrical connection first. Did you use dialectric grease inside the cap?
Next, make sure the wire isn't cut or loose.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 05-09-2004, 08:52 PM Thread Starter
4x4 XJ
I'll go ahead and check that. Thanks. Anyone else?
NP242
D30/D35
BFGs
4x4 XJ is offline
post #4 of 6 Old 05-10-2004, 02:04 PM
97RedBird
2009 MK Compass
I was told that would happen if I placed the o2 at a greater distance from the first o2 on the exhaust manifold. I marked the position with a permanent marker on the floor board before taking off my old cat and used it as a guide line during placement of the new cat. No problems for my 02's.
97RedBird is offline
post #5 of 6 Old 05-11-2004, 09:05 AM Thread Starter
4x4 XJ
So if the o2 sensor is placed too far away from the other, the CEL would come on? Hrmm...let me check that too then. Do you know the exact distance from one to the other?
NP242
D30/D35
BFGs
4x4 XJ is offline
post #6 of 6 Old 05-11-2004, 11:25 AM
97RedBird
2009 MK Compass
I don't know how accurate it needs to be at all, and I don't know if the muffler shop I ordered my cat from was bs'ing me at all. I just know I installed the cat with a new 02 and haven't had any problems. I made sure I did follow the muffler shops direction as to placing the o2 closer or the same distance.
i can measure tonight and have it back in the morning. I'm worried about accuracy. I may measure from the tranny mount back, that way it will be a little easier to look at.
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 11:22 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 01:41 PM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 10:04 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 04:52 PM
