cel cod p1762 - JeepForum.com
post #1 of 4 Old 05-15-2013, 07:04 AM Thread Starter
youpat2
1998 WJ
cel cod p1762
so i replaced the governor sensor and solenoid 3 weeks ago, because it didn't want to drive in first gear. it corrected the problem until 2 days ago the code pop back up.so today it acted up in first gear again. maybe i got bad parts or is it time for a new transmission?
youpat2 is offline
post #2 of 4 Old 05-15-2013, 10:21 AM
Jeeples
Jeeples's Avatar
Where did you get your parts from?
I had replaced mine with the larger Borg Warner solenoid and OE type sensor from Cascade Transmission. My pressure sensor was bad out of the box and I replaced it with one from the local Jeep dealer for about $10 more than I paid for the aftermarket part from Cascade. Once installed my issues and CEL went away.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 4 Old 05-17-2013, 01:27 PM Thread Starter
youpat2
1998 WJ
i brought it of ebay from http://www.ebay.com/itm/251078829812...84.m1497.l2649 the solenoid was one of those bigger heavy duty ones
youpat2 is offline
post #4 of 4 Old 05-17-2013, 04:35 PM
Jeeples
Jeeples's Avatar
It doesn't say anything about where they source the pressure sensor/transducer from. I would suggest stopping by your local dealer and picking one up from them and installing it. I'm willing to bet that will fix your problem.
Jeeples is offline
jeep , transmission , transmission fluid
