ccd help - JeepForum.com
post #1 of 7 Old 07-21-2012, 08:11 PM Thread Starter
dwbarger
ccd help
Ok just purchased a 97 grand. it has some small electrical issues, no radio display, no radio steering wheel controls, no cruise, mirrors lose setting after sitting for a few hrs, driver seat programs dont work, doors do not unlock when vehicle is shut off (pita) tonite on way home the auto headlights starting shutting off randomly, the center console display keeps reading rear tail lamp failure and coolant temp sensor malfuntion. the lights are fine and replaced the sensor. have been searching and looks like all these are related to the ccd??? if so where do i find the ccd in this vehicle?
dwbarger is offline
post #2 of 7 Old 07-21-2012, 08:53 PM
ZeeJay1997
The CCD bus is the wiring and modules that information travels on, so your not going to find it. It is all over.
The coolant sensor bad message on the VIC is a common problem caused by bad solder joints inside the unit. Lots of info on how to fix it on the forum.
The brake light warning is probably due to one of the three high brake view lights light being blown.
Now for the difficults ones, the steering wheel controls may not be working because of a bad clock spring.
The other problems you mentioned are associated with the body control module.
Have you given the electrical system a once over, cleaned the battery terminals, checked all fuses, especially the ones in the fusebox under the hood?
ZeeJay1997 is offline
post #3 of 7 Old 07-22-2012, 04:28 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
And if you get to checking around the airbag/clockspring for sure disconnect the negative batt terminal and wait a few minutes. Isolate the negative terminal so it cant pop over and reconnect.
Originally Posted by HighLonesome
coralman is offline
post #4 of 7 Old 07-22-2012, 04:51 AM
KoreaZJ
1994 ZJ
+1
KoreaZJ is offline
post #5 of 7 Old 07-22-2012, 06:20 AM Thread Starter
dwbarger
Ok im going to do the once over today, thanks for the info.
dwbarger is offline
post #6 of 7 Old 07-22-2012, 06:25 AM
coralman
coralman's Avatar
Seems like I remember reading where a blown bulb where the remaining element piece falls across another element can cause some funky things to happen also.
coralman is offline
post #7 of 7 Old 07-22-2012, 04:22 PM Thread Starter
dwbarger
Checked all fuses, pulled and clean each 1, pulled plugs on pcm n cleaned, didnt get 2 check clock spring yet got wrapped up in rear wheel bearings pinion seal and u joints. Sunroof no longer works now either. Damn jeep anyways
dwbarger is offline
