caution-------------washing the engine ---------caution - JeepForum.com
post #1 of 17 Old 09-10-2003, 10:33 AM Thread Starter
badnews
badnews's Avatar
Well I figuire 77,000 miles I owe the old girl a bath, I degrease the engine and hose it off------------------------- check engine light comes on, oil pressure gauge acting strange, trans will not shift properly. TCP sensor fried, yeap, come to find out if it gets wet, blamo, it is toast and costs 100-200 for repair and diagnostics. warning to all , becareful when cleaning the engine, cover that sensor, or like me you will come to regret it. TCP= throtle control position sensor.
2003 Jeep Sahara --------- Green Jeep club member #51
badnews is offline
post #2 of 17 Old 09-10-2003, 12:29 PM
techie
Where is it? So I make sure it's covered up.
techie is offline
post #3 of 17 Old 09-10-2003, 01:02 PM Thread Starter
badnews
badnews's Avatar
On top near the throttle cables, it is small, black ---------------- oh heck here is a pic the small black item on the end of the electrical connecter. mine is a 1998 GC
badnews is offline
post #4 of 17 Old 09-10-2003, 01:38 PM
techie
I have a 98 GC also, thanks for the pic and the info. I'll be sure to cover that up when I clean the engine. It's funny, I was just thinking today that it was about time to clean it.
techie is offline
post #5 of 17 Old 09-10-2003, 06:56 PM
Swamp Boy
Swamp Boy's Avatar
I spray mine all the time.. And have never had a problem.. Just lucky I guess..
By the way the TPS only cost about $15 or so... Did you acctually spend $200 ?OUCH>.
Sorry to hear that..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #6 of 17 Old 09-10-2003, 07:11 PM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
Yep, I had the same thing happen to me. Degreased the engine, the TPS got wet and then bad, bad things happen. I was scheduled to have some other work done at the stealership and had them fix it (I didn't know at the time what was wrong). They soaked me for around $85.
I don't deal with that dealer any longer.
- Brian
Brian's 97 ZJ is offline
post #7 of 17 Old 09-10-2003, 07:54 PM Thread Starter
badnews
badnews's Avatar
Carl
Yeah, 114.00 out the door, the diagnostic tool that plugs in under the dash is about 5000.00 and since I did not have that, and no one has ever posted on this, that I have ever read, I guess I did get boned. Hence the reason I posted.
badnews is offline
post #8 of 17 Old 09-11-2003, 06:06 AM
msdins
I had a similar problem on my Wrangler once. As soon as I started it up I knew things were not rght, it would barely idle. As it heated up though it was fine. After that I started leaving it running while I sprayed it and never had anymore problems with it.
msdins is offline
post #9 of 17 Old 09-11-2003, 07:53 AM
techie
www.auterraweb.com
Handy little program for those with a Palm Pilot. If you search around, you can find cables and software for laptops also. Obviosly nothing near what the $5000 diagnostic tool does, but at least you can easily see the trouble codes that would be thrown and some stats.
techie is offline
post #10 of 17 Old 09-11-2003, 09:59 AM
Bird
Carl
Where did you find one for $15 - I needed one and the cheapest I found was $46.
Bird
99 Grand Cherokee 4X4
93 Ford Ranger 4.0
Bird is offline
post #11 of 17 Old 09-23-2003, 02:15 PM
basalt51
My co-workers ZJ started idling rough aout three weeks ago. He said when it's idling rough and he gives it gas it barely goes. after a few seconds the problems goes away and it runs full power. When he comes to a stop it begins idling rough again. Does this sounds like the TPS? For $15-$45 it may be worth while to just swap it out. Is it easy?
Thanks
'97 Cherokee Country RE 5.5", 35" Goodyear MT/Rs, RRO Step-Rails, Skid-Row TC and gas tank skids, BPI bumpers, Dynatrac HP44 and Spider9/Tru Hi9 with 4.88s, Explorer discs, and detroits.
basalt51 is offline
post #12 of 17 Old 09-23-2003, 02:26 PM
brad335
TPS is about $30. They are easy to install.
~~Brad~~
brad335 is offline
post #13 of 17 Old 09-23-2003, 02:33 PM
ecrab3
ecrab3's Avatar
Man on man I must have been super lucky all these years then! I soak the crap out of my engine and had no problems, the only thing I really cover up is the computer and the relay center.
Good to know!
Eddie Crab3
'97 XJ
Nuttin Special
ecrab3 is offline
post #14 of 17 Old 09-23-2003, 03:10 PM
ChruiSSer
I wash the engine all the time. Escpecially after those muddy 4 wheelin escapades...no probs here.
Although whenever I was the "car" and not the engine, the air bag light comes on for a couple hours. Then when it dries out I suppose, it goes off.
Replacement for displacement?
ChruiSSer is offline
post #15 of 17 Old 09-23-2003, 05:16 PM
Swamp Boy
Swamp Boy's Avatar
If you cover the computer ... How do you get the mud off of it..
Hell I even wash my air filter...LOL.. I am a non discrimanatory washer... I just go wild..
Carl
washing the engine/ engine bay? PJNovinskee27 ZJ Grand Cherokee Forum 17 08-12-2017 07:44 PM
5.2 wont start after washing engine, im dumb. AEagle326 ZJ Grand Cherokee Forum 29 11-22-2009 08:20 AM
Engine washing questions Dieseljoe WK Grand Cherokee & XK Commander Forum 3 04-17-2007 07:25 AM
Washing the engine bay ///BHRpowered ZJ Grand Cherokee Forum 12 03-25-2006 12:26 PM
pressure washing the engine canadia_driver ZJ Grand Cherokee Forum 7 05-07-2005 01:24 PM
