causes for a pcm to fry? went through 2 - JeepForum.com
post #1 of 6 Old 09-22-2009, 11:14 AM Thread Starter
am9010
My 1996 jeep grand Cherokee stalled out one day and i went through enough trouble shooting to realize it was my pcm that was at fault. i tested for power to it through the black connector and continuity. so i replaced it with a junkyard one that IS COMPATIBLE i have a list of serial numbers of pcms which will plug and play and work with my gc. after i put that in it started up re learned its stuff and it worked fora few days till i was driving down a 4 lane freeway on the left lane and it stalled out (33 mts slow you down verrrrry fast at 70mph, it was a ***** shifting lanes to get to the right) just like it did when my previous pcm failed.
so my question is what causes pcms to fry? i have power going to it. i do realize there is a chance i just had bad luck with a junk pcm, however if i didnt and it was a burst of to much voltage going to my pcm wouldn't a fuse or my asd relay blow and close the circuit to pcm before it gets damaged?
any input helps!
am9010 is offline
post #2 of 6 Old 09-22-2009, 11:19 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
It connects directly to the coil primary, so that is worth a look.
HighLonesome is offline
post #3 of 6 Old 09-22-2009, 12:45 PM Thread Starter
am9010
update: good news my pcm may not be fried, i just found out i do not have power going to it but i have a good ground. i did a continuity test on pin A22 on the black connector because that is the power wire and there was no continuity. pins A31 and 32 both have continuity which are the grounds.
can someone tell me exactly what could stop giving me power to that wire. my asd relay clicks as does every other one
am9010 is offline
post #4 of 6 Old 09-22-2009, 01:48 PM
BlingBlingZJ
I dunno its tricky when the PCM starts acting up. I had to pretty much replace every single sensor thinking one of them was shorting out the PCM but it turned out to be the PCM all along.
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #5 of 6 Old 09-22-2009, 02:49 PM Thread Starter
am9010
son of a *****, i must have been testing my fuse to quickly and didn't realize a 20 fuse blew someone throw a brick at my face, my jeeps running. lol.
am9010 is offline
post #6 of 6 Old 09-22-2009, 02:54 PM
BlingBlingZJ
lol .. glad you got it running
