Catylic Coverter - JeepForum.com
post #1 of 9 Old 11-11-2013, 04:00 PM Thread Starter
davidmatlack
Catylic Coverter
How do you know if one has gone bad? No code has popped up and no rattle in it like my last one that I replaced 100k ago. Muffler is original but no holes/breaks. 264k on vehicle. Had since day one.
Best- David
davidmatlack is offline
post #2 of 9 Old 11-11-2013, 04:10 PM
WJ4x4LIFE
There are two ways a converter can fail:
1.) It can become clogged.
2.) It can become poisoned.
There really is no "inspection port" for someone to view, unless opened by torch. Some may say there usually is a noticeable drop in gas mileage associated with a clogged catalytic converter. A totally clogged converter may cause a lot of known issues with one being, the smell of rotten eggs (theory). I can't say I have smelled this before, but maybe I can smell ****! who knows? A consistently high idle, or erratic idle issue, no hard acceleration issue, and many others. (Symptoms) Physically, you can hear them fall apart from the inside (rattle), or hear them coming apart from the welds over time is a known issue.
WJ4x4LIFE is offline
post #3 of 9 Old 11-11-2013, 04:15 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Search you tube " how to detect bad cat converter". There is a video where a guy uses an infrared thermometer to trobleshoot cats.
Originally Posted by HighLonesome
coralman is offline
post #4 of 9 Old 11-12-2013, 04:36 PM Thread Starter
davidmatlack
Thanks for the reply. Gas mileage has gotten bad 12mpg city and 18 hwy. Hwy fine. Sorry I don't use or ever will, U-Tube.
post #5 of 9 Old 11-12-2013, 05:24 PM
JasonStebbins
It may become clogged which can cause overheating and power issues and the honeycomb inside can collapse.
There's a 100 things that could affect your gas mileage, why do you think the converter is bad?
Poop
JasonStebbins is offline
post #6 of 9 Old 11-12-2013, 06:21 PM
ZeeJay1997
Originally Posted by rlcii77 View Post
my Orvis' never did notify me, by a CEL, that the cat. was even missing, when indeed it is/was... lol
to give a possible explanation of this phenomenon, I suspect that you have not driven the drive cycle required to make the monitor valid.
if you want to try to turn your light on, do this.
Catalyst Monitor Drive Trace
Pre-Conditioning Requirements:
- MIL must be off.
- No DTCs present.
- Fuel level is between 15% and 85% full.
- ECT above 70 F.
- Engine must have run at least 90 seconds
- Engine between 1,350 & 1,900 rpm.
Driving Procedure
1) Idle vehicle for five minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 30 and 45 mph for 2 minutes.
ZeeJay1997 is offline
post #7 of 9 Old 11-12-2013, 07:56 PM
rlcii77
- MIL must be off.
- No DTCs present.
- ECT above 70 F.
Driving Procedure
Wow, had no idea there were so many prerequisite conditions to meet for that to call to function... Thanks for sharing that ZeeJay1997 ! !
Sent from Lee's Samsung Galaxy Note II using JeepForum
'72 CJ5 Ren
'91 XJ, '96 XJ, '98 XJ
'94 ZJ, '96 Orvis ZJ
'98 Platinum 5.9, '98 Slate 5.9 (DD)
rlcii77 is offline
post #8 of 9 Old 11-15-2013, 07:08 AM Thread Starter
davidmatlack
Suggestions for replacement Cat and Muf
Rock Auto has a wide variety of these. Any suggestions on the best OEM replacement? Same loudness?
Best- David
post #9 of 9 Old 11-15-2013, 07:24 AM
zjosh93
A lot of people, myself included, have had luck finding Magnaflow cats on Amazon for less than even the RockAuto prices. I just went to Magnaflow's website and looked up the recommended universal cat for a 4.0 and made sure not to go smaller than that. I ended up with a 2.5" version. No idea what part number and it would be different with yours having a rear O2 anyway. No change in loudness really and it has passed the state emissions every year since with no issues.
zjosh93 is online now
