Catalytic converter Bypass Pipe - JeepForum.com
post #1 of 19 Old 06-12-2003, 10:50 AM Thread Starter
Herb Jenssen
Anyone out there know where I can purchase a bypass pipe for a 94 ZJ 318?
My converter went bad (noisy).
Thanks
Herb
Herb Jenssen is offline
post #2 of 19 Old 06-12-2003, 10:52 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Get a new converter and be done with it. They aren't much more than 200.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 19 Old 06-12-2003, 10:55 AM Thread Starter
Herb Jenssen
I guess that means you don't know where to get one?
I asked about a bypass pipe.
I know where to get a converter.
Thanks
Herb
post #4 of 19 Old 06-12-2003, 11:03 AM
ViPER_SR2001
How did you come up with this idea???
Either buy a new one, or put a straight pipe on it!
ViPER_SR2001 is offline
post #5 of 19 Old 06-12-2003, 11:15 AM
97RedBird
2009 MK Compass
Agreed,
cut before and after the cat
let it fall
replace with straight exhaust pipe
clamp or weld into place
I personally chose to replace it with a Catco, and love the gas mileage improvement.
Don't know if you have o2 sensors or a computer, but you may get an error code you will have to ignore.
97RedBird is offline
post #6 of 19 Old 06-12-2003, 11:16 AM Thread Starter
Herb Jenssen
I came up with this idea when it started making noise today.
I called around and the best price was $150.00 installed.
I can get one on the web for $89.00 but while I was under the car I thought why not just eliminate it.
I need to drive the Jeep on the street so a straight pipe is out of the question unless you mean a straight pipe to replace the converter. If this is the case that's exactly what I want.
I apologize to you and the other reply for using the wrong terminology.
Thanks
Herb
post #7 of 19 Old 06-12-2003, 11:21 AM Thread Starter
Herb Jenssen
Red Bird,
Where did you get your Catco?
What kind of mileage improvement did you get?
I don't have a torch so I imagine it will be a b____ to get off.
Did you cut yours off and then replace it?
Thanks
Herb
post #8 of 19 Old 06-12-2003, 11:32 AM
97RedBird
2009 MK Compass
Sorry it was CarSound not Catco,
I ordered it from http://www.warpspeedperformance.com/jeep.htm
I talked with them on the phone and they sent me out the cat, muffler, clamps, and adaptors. Muffler is a louder than stock, but the combination keeps our jeep at 20-22 mpg with 50/50 city highway driving all the time.
we were referring to a straight pipe as just a foot and half length of 2 1/2" exhaust pipe. the pipe replacement will work and is very cheap intitially, but I don't know how the gas mileage will be.
If you have a sawzall, cut the thing out yourself and put it back together and same yourself a lot of money. I borrowed a sawzall from my neighbor and put it in.
post #9 of 19 Old 06-12-2003, 11:36 AM
97RedBird
2009 MK Compass
Your terminology was fine, I just thought it was funny to bypass the converter. Because the way you stated it is true.
You see it as bypassing the cat.
I just see it as removing the cat.
To each their own. both are correct statements and it's funny I would never have saying anything else. I'm just stuck in a one track mind I guess.
post #10 of 19 Old 06-12-2003, 11:39 AM
97RedBird
2009 MK Compass
When clamping the exhaust pipes, I did purchase exhaust pipe repair glue and used it as a sealant before I tightened the clamps. Worked good on my old cars so I thought it wouldn't hurt on my jeep.
Now I have a welder so I would probably do that next time.
post #11 of 19 Old 06-12-2003, 11:53 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You may or may not have check engine light issues if you go with the straight pipe.
You can use a dremel tool with a carbide tip cutter to take cut the pipe. (just wear safety glasses)
I'm guessing that you still want the cat. Redbird is really hooking you up.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #12 of 19 Old 06-12-2003, 12:03 PM Thread Starter
Herb Jenssen
I'm not sure whether I want the cat or not.
I guess my Jeep was trying to tell me something because I would get a check engine light every so often but it would go out as soon as I shut it down and started up again.
I probably have a bad O2 sensor and maybe by ignoring it my cat went bad.
I don't know. I've got 152,000 on the ZJ so maybe the cat was ready to go. I guess I better check out the O2 sensor.
I'll say one thing about this forum.
Somebody "ANSWERS" you!
I've asked questions on another forum called Quadratec and never get a reply.
ThankYou!
Also, does someone make a straight pipe to replace the cat or do you have to fabricate your own?
Later
Herb
post #13 of 19 Old 06-12-2003, 12:46 PM
CATMAN2
I REPLACED MINES ON STAURDAY. THEY RAN A STARIGHT PIPE AND ALSO PUT THE O2 SENSOR IN IT. HOWEVER CHECK ENGINE LIGHT DID COME ON.....IF ONLY I GET IT OFF.
CATMAN2 is offline
post #14 of 19 Old 06-12-2003, 01:40 PM
97RedBird
2009 MK Compass
I like to check this forum for jeep stuff and fbody.com for my TA stuff. I love seeing everyone's answers.
the straight pipe - I've gone to Midas and bought 3 foot of pipe real cheap before.
cat might have caused the 02 to go bad also. Either way they can do that to each other.
I had to replace my cat after only 110k miles and the o2 failed after reinstalling it on the new cat so I replaced it. I had planned on replacing it anyways so I wasn't to dissappointed.
post #15 of 19 Old 06-12-2003, 02:24 PM
ViPER_SR2001
You can also buy a simulator for the o2 sensor... no check egine light!
catalytic converter - test pipe tapenick ZJ Grand Cherokee Forum 1 01-11-2010 08:52 PM
how to tell if catalytic converter is bad rocks00tj WK Grand Cherokee & XK Commander Forum 4 09-25-2008 12:15 AM
Catalytic Converter: Need a New One JoshuaDHarp ZJ Grand Cherokee Forum 11 09-10-2008 06:42 AM
Straight Pipe replacing Catalytic Converter jeff_connors ZJ Grand Cherokee Forum 3 04-06-2008 05:01 PM
replacing the catalytic convertor with stright pipe ? jeepunlimited ZJ Grand Cherokee Forum 4 01-25-2008 06:55 PM
