CAT Removal Procedure - JeepForum.com
post #1 of 25 Old 09-20-2007, 05:42 PM Thread Starter
kdavis
kdavis's Avatar
Got my new CAT in today, went under there to start the install, only to realize...holy crap this things been on here for 180K miles...
Is there a method to this madness, or is it just brute force? I got the clamps loosened, just not sure how to remove the cat from the pipes.
Thanks.
<>< KD ><>
2004 TJ Wrangler Rubicon (Sugar High)
kdavis is offline
post #2 of 25 Old 09-20-2007, 05:46 PM
CLNinja
CLNinja's Avatar
BFH
12345678910char
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #3 of 25 Old 09-20-2007, 05:48 PM Thread Starter
kdavis
kdavis's Avatar
That took me a second...and I got it. Will the rear pipe retainer slide far enough out of the way, or do I have to unbolt it?
<>< KD ><>
kdavis is offline
post #4 of 25 Old 09-20-2007, 05:50 PM
indept
a BIG DOG usually gets the cat out...Sorry couldn't resist
You need to heat the pipe red hot using oxy/ acetylene then bang the crap out of it.
indept is offline
post #5 of 25 Old 09-20-2007, 07:17 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Screw that...cut it off with either a sawzall, dremell, or my favorite, a grinder
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 25 Old 09-20-2007, 07:18 PM Thread Starter
kdavis
kdavis's Avatar
Do you guys think it would be easier to cut the cat then get the remnants off? I heated the thing up, didn't budge. I even tried taking my hydraulic jack sideways to it to see if I could get it off. I haven't given up yet, but if I could just cut it off with a sawzall, might be the way to go.
HA, that's funny, you were typing while I was...sawzall it is...
<>< KD ><>
kdavis is offline
post #7 of 25 Old 09-20-2007, 07:19 PM
CLNinja
CLNinja's Avatar
cut it
124567
Matt
CLNinja is offline
post #8 of 25 Old 09-20-2007, 07:22 PM
gunthagunth
gunthagunth's Avatar
definitely cut it. I used a cutoff wheel to make a cut along the pipe, then peeled it back some and still had to beat the bag out of it. Then just welded it back up. Pickup one of those exhaust tailpipe expanders, that thing would work pissah compared to what I went thru.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #9 of 25 Old 09-20-2007, 07:39 PM Thread Starter
kdavis
kdavis's Avatar
I'm thinking if I can get it cut without getting into the exhaust, but leaving enough to grab onto, I can more or less beat the peices out after ward...just realized I'm out of metal sawzall blades, so off to the store tomorrow.
I'll report back later. I wish I had a cutting torch here.
<>< KD ><>
kdavis is offline
post #10 of 25 Old 09-20-2007, 07:40 PM
CLNinja
CLNinja's Avatar
buy a plasma cutter
Matt
CLNinja is offline
post #11 of 25 Old 09-20-2007, 07:49 PM
driabyor
driabyor's Avatar
1994 ZJ
tail pipe cutter
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #12 of 25 Old 09-20-2007, 08:17 PM
gunthagunth
I tried cutting it back into tabs and peeling them back. It took forever and was definetly not worth it. I use one of these to expand it for a new pipe.
http://www.partsamerica.com/productd...egoryCode=3494
post #13 of 25 Old 09-20-2007, 09:31 PM
sandman
i cut slits in the cat where it overlaps the pipe then it slid right off.
1993 Jeep ZJ. 4.0
sandman is offline
post #14 of 25 Old 09-20-2007, 09:42 PM
alivenkickin28
cut mine off way up on the pipe toward the cat so that i woudnt cut my exhaust pipes -- then i took a sawzall and got the rest out of the exhaust pipes -- took a hour but it worked...
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #15 of 25 Old 09-20-2007, 10:08 PM
indept
You used the guy & girl standing at the counter to cut it off
That link just goes to Partsamericas's front page, not a specific tool or anything.
Correction, they wanted my zip first, THOSE BASTAGES
indept is offline
Best 50K mile tune up procedure? KDOG2008 ZJ Grand Cherokee Forum 8 08-14-2008 09:31 AM
Where Is That Procedure For Displaying Codes? WKTrailRunner WK Grand Cherokee & XK Commander Forum 5 05-07-2008 12:24 PM
procedure from 4hi to 4lo 69speed ZJ Grand Cherokee Forum 3 10-08-2007 10:33 PM
Valve Cover Removal - 4.7 - Procedure? NoOne2 WJ Grand Cherokee Forum 4 08-11-2007 05:19 PM
Cleaning procedure Endurancevm ZJ Grand Cherokee Forum 5 03-18-2006 06:08 PM
