Cat converter failure 96 GC 4.0L - JeepForum.com
post #1 of 5 Old 08-06-2009, 12:04 PM Thread Starter
dannye1987
So I finally pulled the engine codes thanks to some people here on the forum.
I got the error code of 72 and 12 (battery one which I dont think is a problem since I had to be boosted not long ago). And 72 being the cat converter failure, my question is, can I just replace that with a straight pipe or a resonator? Or do I need to put a new cat converter in? I know with the OBDII systems, there is a sensor on both ends of it and it would need to be replaced, but I am pretty sure its an OBDI system.
Thanks,
Danny
dannye1987 is offline
post #2 of 5 Old 08-07-2009, 08:58 PM
xjhavens
you have to bite the bullet and by a new cat. in order to pass inspection the cat has to be there. if you just ran your heep on trails only you would be ok with removing the cat.
xjhavens is offline
post #3 of 5 Old 08-07-2009, 09:04 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you're obdii, be nice to the environment and pay the 75$ for a carsound high flow replacement.
ratmonkey is offline
post #4 of 5 Old 08-07-2009, 09:07 PM
WhiteOut
WhiteOut's Avatar
Yay! Another calgarian!
Danny, we dont have to have a cat on our Jeeps but I would highly suggest one. I ran for a while just straight piped and it didnt really run too well. Are you still stock or modded. PM me. I can help you with the CEL as well.
WhiteOut is offline
post #5 of 5 Old 08-07-2009, 11:58 PM
elmer_fud
if you run a strait pipe you will probally keep the check engine light for a bad cat. The system recognizes the cat as working by there being less (or more) oxygen sensed by the post cats o2 sensor
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
PCM failure joshjeep04 ZJ Grand Cherokee Forum 5 05-22-2010 10:47 PM
PCM Failure...what now? lasvegas ZJ Grand Cherokee Forum 6 11-01-2009 07:58 PM
PCM Failure Common? Causes? XJH-007 ZJ Grand Cherokee Forum 9 09-11-2009 05:17 PM
possible VC failure on 93 ZJ 5.2? jvb6806 ZJ Grand Cherokee Forum 5 11-29-2008 09:54 PM
ATC Failure drdandavis ZJ Grand Cherokee Forum 3 02-01-2007 07:26 AM
