Car hesitates - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Car hesitates
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 10-12-2014, 11:48 PM   #1
midosaid
Car hesitates
2006 jeep grand cherokee leardo 3.7L its about 140,000 miles. It was driving fine, the RPM was little not steady,
So time for some tune up, I used 2 seafoam in the gas tank back to back, then I change
the spark plugs, air filter, the oil, the throttle position sensor, it drive great for a week, then the car start to hesitates, and sputters when I drive on steady speed, not all the time.it start fine and no check engine light one
any ideas why is this happening?
Oh also what is ZJ -WJ jeep ?
midosaid is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 12:53 AM   #2
Alexandru999
1) did the previous owner do a seafoam at all in that mileage?
2) from what you say, could be as simple as an O2 sensor, i know certain symptoms i had like 3 y ago were kinda what you describe and it was o2 sensor and tps, eventually the check engine will appear, mine did after like 1 week give or take, if its o2 sensor
Alexandru999 is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 09:13 AM   #3
midosaid
I dont know if the previous owner used seafoam or not , i have the jeep for 5 years now , and every now and then i use the seafoam , i went to autozone and they told me its the fuel filter which it will coast $110 , and its inside the tank !!
Unread 10-13-2014, 09:41 AM   #4
ZeeJay1997
Originally Posted by midosaid View Post
ZJ -WJ jeep ?
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 11:35 AM   #5
midosaid
Thanks Zeejay1997 , im using the app and not showing the decryption .
