Car Dying at Idle? - JeepForum.com
post #1 of 8 Old 11-26-2010, 01:00 PM Thread Starter
96jeepman
Car Dying at Idle?
Hey guys,
Have a 96 ZJ Inline 6. I have had a slow battery drain. But recently had both my battery and alternator tested as good. Any Ideas as to why the zj would not be able to hold idle causing it to die? Its fine under power but as soon as I take the foot of the gas the rpm's drop and engine dies. Thanks
Rubicon express 4.5 inch lift. OME nitrous charger shocks. 15x8 craggar soft 8's and 32x11.5r15 bighorns . Elemtal Design Componets, amps and 10 inch subwoofer
96jeepman is offline
post #2 of 8 Old 11-26-2010, 01:07 PM
bigvjp
zj help
it has to be the battery ,it will run with higher rpms off alt. but at idle battery needs proper volts ot stay running tps wont read signal. hope this helps.
bigvjp is offline
post #3 of 8 Old 11-26-2010, 01:32 PM Thread Starter
96jeepman
battery is new could it be a bad ground to the battery?
post #4 of 8 Old 11-26-2010, 03:26 PM
KevLaredo
1997 XJ Cherokee
It doesn't like being called a car and is mad at you.
-97 XJ Cherokee Sport. Bone Stock. Inline 6, selec-trac and factory tow package with Chrysler 8.25 Rear. ▀ lllllll ▀
-98 White ZJ Grand Cherokee Laredo. 3.5" Rough Country Lift, Manik Brush guard, Hella 500 Fogs, 31x10.50x15 Cepek Crushers, K&N cold air intake, 4.0L I6, Cobra CB. SOLD
KevLaredo is offline
post #5 of 8 Old 11-26-2010, 05:42 PM
bigbossd1030
Try a new battery, these jeeps will not run properly without a good battery.
Just do this test, pull a good battery from a diff vehicle and put it in the jeep, if it still does it, then its not the battery, if it runs fine, then you know it was the battery.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #6 of 8 Old 11-26-2010, 08:01 PM
CharlesW16
Most likely the battery, though it could be the alternator, if it isn't supplying sufficient voltage/amperage to the battery at idle. If my battery is a little weak (forgot to turn the lights off or something) it idles really slow until it gets charged back up.
Horsepower is how hard you want to hit the wall. Torque is how far you want to take the wall.
CharlesW16 is offline
post #7 of 8 Old 11-26-2010, 08:09 PM
highlyuncntered
Replace the IAC motor. I had a '99 Wrangler 4.0l that did the same thing. Ran just great until i took my foot off the gas, then nothing. Advance should have it for about $45.
"Si Vis Pacem, Para Bellum"
'98 ZJ Limited V8 "Daisy"
highlyuncntered is offline
post #8 of 8 Old 11-27-2010, 09:04 AM
straight-pipe
It could be a simple thing as a very dirty throttle body. My 5.2 wouldn't idle last year so I manually bumped up my idle and my fuel mileage wasn't very good either. I found out that my throttle body was caked with crap around the butterflies. I cleaned it up using a sensor safe intake cleaner and a soft brush. started the engine and sprayed the cleaner in the intake while feathering the throttle so that it wouldn't stall....the idle jumped up to 1700! I backed the idle screw back down to factory and everything is normal once more and got my fuel mileage back as well!
94 ZJ 5.2L
07 JK 3.8
straight-pipe is offline
98 gc dying and need help plz! bmx_hb_guy ZJ Grand Cherokee Forum 29 08-15-2016 11:49 AM
Low Idle/Dying When Not In Gear tb123 ZJ Grand Cherokee Forum 4 02-23-2009 10:23 PM
The 4.0 is dying. rxl ZJ Grand Cherokee Forum 21 08-24-2007 09:12 PM
Keeps dying when gets hot outside lwbangedup ZJ Grand Cherokee Forum 2 10-07-2005 04:22 PM
'97 GC Dying? franjj047 ZJ Grand Cherokee Forum 2 09-28-2005 11:49 AM
