Can't take front brake rotors off, need help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Can't take front brake rotors off, need help!
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-06-2008, 11:32 AM   #1
shahriarrrr
Hi,
Yesterday I bought all my rotors and tried to change them, the rear ones came out really easy after removing the calipers, but I couldn't take the two fronts off, is that tricky or something?
in the FSM, it's indicated that I should take the retainers off to be able to take the rotors off, but there is no retainers there!
any advise in form of pictures, last experiences etc. is really appreciated.
1999 Grand cherokee 4.7 V8
shahriarrrr is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 11:36 AM   #2
a70eliminator
Heat and beat, your trashing them anyways right.
a70eliminator is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 11:46 AM   #3
JeepOrvis97
I did my 2002 WJ brakes, once you have the whole caliper off, bracket and all, they were still stuck, I took an Air hammer and hammered on the center of the brake to break up the rust, then a sledge on the back of the rotor all the way around, then I took a crow bar and wedged it on one of the caliper mounts on the knuckle and pryed the rotor off, it wasn't too hard.
JeepOrvis97 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 11:57 AM   #4
Turbonut
Put the lug nuts on the studs to protect the threads, then hit all around the rotor hat to break the rust free.
Any type of excessive heat, sledge hammer tatics may have an adverse affect on the hub.
Turbonut is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 12:57 PM   #5
painted600rr
i just did mine a week ago. i had to beat the **** out of them with a sledge hammer.
painted600rr is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 04:25 PM   #6
JeepOrvis97
Any type of excessive heat, sledge hammer tactics may have an adverse affect on the hub.
I used the "sledge hammer tactics" seemed to work fine. How else do you expect to get it off without a hammer? I used a rubber mallet as well but it didn't do anything.
Unread 04-06-2008, 05:29 PM   #7
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Use hammer with common sense and you will be fine.
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 05:47 PM   #8
JLH
Just use a BFH and you will be fine.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 07:05 PM   #9
UltimatE
Resident Audio Guru
UltimatE's Avatar
+1 on the BFH
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 07:06 PM   #10
Turbonut
I believe you'll find that there is a difference between a sledge hammer and a regular hammer. At least in my part of the world.
Unread 04-06-2008, 07:13 PM   #11
JeepOrvis97
I used a rubber mallet and a sledge hammer. The thing however that worked the best was the crowbar. I just kept working my way up to more leverage. Constant leverage is the best rather than smacking something, but I didn't notice that nice little mount that I could pry off of! The sledge was just part of my trial and error, but I thought it must have done something because I couldn't move it with just the crow bar when I went over to do the other side.
Unread 04-06-2008, 08:16 PM   #12
TX-WJ
TX-WJ's Avatar
Followed by the ole BFH
David.
2004 WJ Ltd. (steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 04-06-2008, 08:42 PM   #13
shahriarrrr
Thanks for all the recommendations, I did it with a sledge hammer, but before that I put some freeze-off and then some penetrating lube spray before opening the caliper and by the time I used hammer, Bingo!
Unread 04-06-2008, 08:44 PM   #14
JeepOrvis97
Congrats!!!
Unread 04-07-2008, 08:47 AM   #15
LEDFoot
Violence is the answer.
--Martin
_____________________________________
'99 WJ 4.7 Quadra-Drive w/ 242HD swap... 2WD since my front diff is kaputt :(.
LEDFoot is offline   Reply With Quote Quick reply to this message
