Can't quite find the info I need for mid 70s 318 and 904 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Can't quite find the info I need for mid 70s 318 and 904 swap
Warn, Smitybilt, Engo, Rugged Ridge Winches at CCOR50% Off Sale at KrawlOff-Road.comBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and C
Unread 01-31-2013, 08:09 PM   #1
stockzj
I already have the 318 and the 904 so I just need info on mounts for the trans and 318. Are the motor mounts the same as the 318 that comes in the zjs or do i need 70s motor mounts. Does anyone know what it will take to mount the 904 in the jeep. I am going to pull the motor and trans soon any way and see what i need to make it work. I just want to see if anyone can tell me what i need so i can prepare
97 ZJ with 31x10.5 Ravines spacers 2" bb rough country shocks 8 kcs 204k xj marker light doorless
stockzj is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 08:33 PM   #2
dnuccio
youre trying to put a 70s 318 and trans in a 97 4.0 ZJ? good luck, thats all i can say
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 09:57 PM   #3
ratmonkey
R.I.P.
ratmonkey's Avatar
yeah....not a bright swap. 70's 318's had less power and torque than your 4.0.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 10:22 PM   #4
stockzj
My 4.0 is dead and the 318 has been stroked among other things
Unread 02-01-2013, 12:05 AM   #5
ratmonkey
R.I.P.
ratmonkey's Avatar
add mpfi and you'll be good. but it's a major swap no matter how you slice it
Unread 02-01-2013, 07:18 AM   #6
dnuccio
How are you going to deal with all the electronics? You're talking about putting a carbed engine in an OBDII vehicle. The computer is gonna go crazy
R.I.P. Ratmonkey
Unread 02-01-2013, 10:29 AM   #7
ratmonkey
R.I.P.
ratmonkey's Avatar
Yeah, the swap isn't emissions legal no matter how you slice it. You'll also be losing overdrive and the lock up torque converter using that transmission.
All around, bad idea.
Unread 02-01-2013, 04:51 PM   #8
stockzj
Ditching all the electronics and is exempt from passing emissions in MA, if the 904 will not be good for the swap what should I use
Unread 02-01-2013, 06:25 PM   #9
ratmonkey
R.I.P.
ratmonkey's Avatar
it's not exempt from federal law. can't swap in a motor that is older than the manufacture year of the vehicle or one that wasn't offered in that vehicles line up as an option.
Unread 02-01-2013, 07:00 PM   #10
dnuccio
say goodbye to your gauges, they are all controlled by the electronics.
seriously not worth the work, if you want a V8, go buy a stock V8 ZJ. alot less work and probably alot cheaper too. not like theres a shortage of them
R.I.P. Ratmonkey
Unread 02-01-2013, 07:59 PM   #11
stockzj
Chances are it won't go back on the road
