Quantcast Can't Open tailgate - 97 JGC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Can't Open tailgate - 97 JGC
Old 04-06-2008, 04:43 PM   #1
shockwave
I can't open my tailgate. The thing unlocks and locks with the key but if doesn't seem to be engaging when I use the handle. I tried to take of the back panel but I can't seem to get it off to look at it. Any suggestions?
shockwave is offline   Reply With Quote
Old 04-06-2008, 05:53 PM   #2
scarbound
Yeah mine used to do this. Easy fix. What you gotta do is drop a knee about 2 inchs to the right of the handle while at the same time pulling the handle lol. Works every time for me.
98Grand Cherokee Laredo 2 inch. BB on 31X10.5 Uniroyal Liberator A/Ts..
scarbound is offline   Reply With Quote
Old 04-06-2008, 06:07 PM   #3
Windowsrookie
This is also why most ZJ's have a dent next to the handle, like mine.
Once you get it open grease it up a little, if it does it again you need to adjust the handle.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline   Reply With Quote
Old 04-06-2008, 06:52 PM   #4
shockwave
Ok i got it open and i took the panel off. With it open I was playing around with it and got it to engage on a screwdriver, I can't get it to disengage. So now the hatch won't shut. I don't see how I can take that part out either with the screwed in rod screwed in to something on both sides and the lack of space availble.
Also, the hydraulic rods that hold the liftgate and tailgate window open just keep coming down. Does this mean I have to replace all 4 hydraulic rods?
Thanks
Old 04-06-2008, 07:07 PM   #5
a70eliminator
It's amazing what a little oil will do, the little spring return cam latch is hanging up on ya, get a can of spray lube or better yet plain oil and squirt the crap out it saturate it good any excessive oil will creep into the pinch weld and keep you hatch from rusting along the bottom so don't be afraid of really douseing it good. And your hatch cylinders are shot too.
a70eliminator is offline   Reply With Quote
Old 04-06-2008, 08:04 PM   #6
shudog
Haha, I just posted the exact problem about my hatch not opening...
I replaced the two main hydraulic supports last fall though, no big deal. The two that support the glass aren't really an issue.
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac
White w/gold trim - totally stock
shudog is offline   Reply With Quote
Old 04-08-2008, 04:08 PM   #7
shudog
so to fix that sticky tailgate, just give it a firm bump with the knee, then take it apart and lube it up?
How about replacing the rubber hatch stops on either side? Mine are totally disintegrated and cracked and worthless, where can I get new ones?
Old 04-08-2008, 04:15 PM   #8
squashman702
Mongo-fabbed
squashman702's Avatar
Exactly what I do, and x2 on that dent.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote
Old 04-08-2008, 08:59 PM   #9
shudog
So how 'bout those rubber hatch stops? Anyone know where I can get them?
Old 04-08-2008, 09:01 PM   #10
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I got mine at the stealership..... and they were about $30.00 for the pair....
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
SpeedyCat3 is offline   Reply With Quote
Old 04-08-2008, 10:09 PM   #11
wil badger
I call my hatch the Fonzy hatch .Pull up on the handle and give it a little thump with your free hand and it opens right up.
One Built XJ
wil badger is offline   Reply With Quote
Old 04-25-2008, 08:28 PM   #12
shudog
Got the rubber stops from the dealership today for $7 ea. Installed them and took the back hatch cover off and lubed the heck outta the handle & latch mechanism. Fixed the rattle and the hatch opens the way it's supposed to now. Think I'll drink a beer now.
Old 05-03-2008, 08:23 PM   #13
ruhypoxic
I had this same problem. My daughters keep a ton of useless stuff in the rear (blankets, sleeping bags, clothing) and this stuff kept getting jammed in the rear latch. I did finally get them to clean this out but I wonder if these jams didn't cause the latch to start malfunction because we are now experiencing hard to open liftgate problems. Does anyone have a better fix than pulling and pushing at the same time that won't cause more damage to the rear? Any help is appreciated.
Thank you.
ruhypoxic is offline   Reply With Quote
Old 05-03-2008, 08:59 PM   #14
SpeedyCat3
Survivor
SpeedyCat3's Avatar
When you have it opened, yake the panel off and lube the mechanism.
Make sure the bolts that hold the latch on the bottom are there and tight.
Maintenance is usually overlooked on tose things.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
Old 05-03-2008, 09:33 PM   #15
adgroza
i just give light pressure with my palm while pulling the handle. and by the way, all those rubber pieces do is keep the tailgate in visual alignment. like everyone else says. if enough water gets in to rust the hatches, the latch isnt far away, so it gets wet and corroded.
adgroza is offline   Reply With Quote
Glock Forum
