cant get my front driveshaft out - JeepForum.com
post #1 of 9 Old 04-22-2007, 09:51 AM Thread Starter
acidspit86
how do i get the front driveshaft out? i unbolted all the bolts i could see on the transfer case and on the front differential. i was able to get the shaft off of the front diff, but it wont budge from the transfer case.... am i missing something is there some special trick?
acidspit86 is offline
post #2 of 9 Old 04-22-2007, 09:57 AM
jeepmech06791
jeepmech06791's Avatar
Make sure that you have all 4 bolts off on the back of the diff flange on the t case side and either use the drive shaft (given that its unbolted from the front axle) like a bar and just give it a yank, or put a large screwdriver or a pry bar in the cv part of the shaft to give it some love, shel pop off so long as you have it all unbolted.
91 yj, swaped 4.0, ax15, twin stick stak case, one inch daystar bl, SOA, Waggy 44 front, 8.8 rear, 35x12.5 BFG KM2, Allied Rock 8 bead locks, AGR hydro assist, m8000 warn
jeepmech06791 is offline
post #3 of 9 Old 04-22-2007, 10:43 AM Thread Starter
acidspit86
all 4 bolts?
from what i can see, there are 6 bolts holding it on each side (differential side, and t-case side)
00 grand cherokee 4.7
post #4 of 9 Old 04-22-2007, 11:05 AM
TravisL1213
on the wj there are 6 bolts on each side. i had the same problem. remove the 12 bolts and with all 4 wheels on the ground twist the ds with ue hand untill it breaks loose, then it will compress and slide right out.
i just crawled under and gave it a big kick and it came loose
Limited WJ on 31's
TravisL1213 is offline
post #5 of 9 Old 04-22-2007, 11:08 AM
TravisL1213
post #6 of 9 Old 04-22-2007, 11:43 AM
impuresoul2k3
I used a 6" extension to pry it off the yoke and it came right off.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #7 of 9 Old 04-22-2007, 12:03 PM
AgitatedPancake
there arent necessarily 6 bolts per side on all WJs. Mine had 4 per side.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #8 of 9 Old 04-23-2007, 07:57 PM
jeepmech06791
to be honist i didnt even notice it was a wj, I was thinkin standard yj-tj-xj stuff, but eather way, make sure its all unbolted and use a bar, shel come off
post #9 of 9 Old 04-24-2007, 08:12 AM
matt.x
matt.x's Avatar
a couple soft taps with a hammer did the trick for me... course I have ZJ and the DC joint, so maybe somethings a little different here...
Red Jeep Club Member #237
matt.x is offline
front driveshaft lateralus3 ZJ Grand Cherokee Forum 8 12-19-2009 10:24 PM
front driveshaft normes ZJ Grand Cherokee Forum 2 08-01-2009 10:56 PM
Front driveshaft too long after swapping front differential jjeeeeppss ZJ Grand Cherokee Forum 11 08-12-2008 05:19 PM
Front Driveshaft GibsJeep ZJ Grand Cherokee Forum 8 01-02-2008 04:05 AM
Bad VC, can it be run without the front driveshaft? 93jeep93 ZJ Grand Cherokee Forum 5 01-11-2006 08:32 AM
