can't get axle out - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > can't get axle out
Unread 02-06-2016, 10:50 PM   #1
silverstr8p
can't get axle out
I got the rest of the assembly off, and then beat on this thing with a big hammer and chisel to try to pop it loose, but am afraid of overdoing it, am I missing something that still needs to get unbolted, or should I continue with increased wailing or is there a better way to get it off?
As you can see on the ground, I got the three bolts out that hold it to the rest of the hub.
silverstr8p is offline   Reply With Quote Quick reply to this message
Unread 02-06-2016, 10:58 PM   #2
wingless
wingless's Avatar
1994 ZJ
When I did mine it also did not want to come apart.
The method I used was to put a cold chisel between the splash shield and the steering knuckle, assisted by a BFH on the chisel.
The splash shield was slightly degraded, so I pressed it flat w/ my shop press.
wingless is offline   Reply With Quote Quick reply to this message
Unread 02-06-2016, 11:10 PM   #3
wingless
wingless's Avatar
1994 ZJ
This shows the steering knuckle w/ the wheel bearing, splash shield and axle half shaft removed, w/ the axle sanded and painted.
Unread 02-06-2016, 11:27 PM   #4
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
See pic below. Put a bolt, or deep well socket there on the stub axle u-joint ear, and turn the steering wheel. Done.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 02-06-2016, 11:40 PM   #5
tjcustomranger
Yup, thats the way to do it.
tjcustomranger is offline   Reply With Quote Quick reply to this message
Unread 02-07-2016, 04:21 AM   #6
Timo_90xj
Timo_90xj's Avatar
^- yeap, that's the right way to do it - and by far the easiest.
Trying to chisel out a stuck unit bearing will only ruin the knuckle. When installing a new unit bearing, use fine-grit sandpaper to clean off all the rust from inside the knuckle bore, then lube unit bearing outer surface and knuckle bore mating surfaces with anti-seize or copper paste; also use a light amount of anti-seize on the unit bearing mounting bolts and torque to specification
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 02-07-2016, 05:32 PM   #7
riot1987
I always use a slide hammer. Thats a way better idea. Awesome!
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2016, 06:05 PM   #8
CJ7-Tim
CJ7-Tim's Avatar
A slide hammer is not a good idea if you want to re-use the unit hub. They have a tendency to wreck the bearings.
Unread 02-08-2016, 12:04 AM   #9
Candymancan
Turning the wheel sometimes doesnt work.. didnt work for me.. But i came up with that idea also. Buy a bolt from the hardware store that threads into the bearing.. Then thread it up like 4-5 turns and get a small sledge hammer and pound the bolt.. Itll pop the wheel bearing off eventually. Reason why i say new bolt is because if you re-use the old ones and smash with a hammer.. it will flatten the ends and you cant get a wrench on them anymore.. But the new bolt you can just use vicegrips to get off since its sticking out.
And you want to keep the old bolts.. i couldnt find new grade 8 bolts that size.. in ANY hardware store.. only grade 5 so thats hwy i say get a new cheap bolt for the pounding.
When you put everything back together.. Get some wheel bearing grease.. Put some on the new axle splines, and lather up the wheel bearing and the Hub this way it wont rust itself together again
2013 6.2 V8 Camaro SS 9k miles
1998 5.9 V8 ZJ 180k miles
1998 4.0 I6 Laredo ZJ 227k miles
Candymancan is offline   Reply With Quote Quick reply to this message
Unread 02-08-2016, 12:45 AM   #10
Timo_90xj
Timo_90xj's Avatar
OEM bolts have a thicker shank right before the flange. You can use grade 8 or ISO class 10.9 (or 12.9) metric bolts for mounting the hub, but OEM bolts are better.
Like I mentioned above, use anti-seize or copper paste. Both stay on the mating surfaces better, and anti-seize is a much better option on the mounting bolt threads compared to bearing grease
Unread 02-08-2016, 01:01 AM   #11
Candymancan
well all i had was grease.. better then nothing right ?
Unread 02-08-2016, 01:21 AM   #12
Timo_90xj
Timo_90xj's Avatar
Certainly
Unread 02-08-2016, 01:28 AM   #13
Candymancan
I hate the 4.0 i have though.. Its hard to work on, lived here in VA all its life for 17 years weve had it.. The 5.9 was built in canada and mostly on the west coat..
Certainly a huge diff in how easy these two or hard they are to work on.. the 5.9's hubs.. poped right off, the 4.0 took me hours.. Same goes with everything else.. If the engine and trans werenly so damn reliable on the 4.0 id personally melt the vehicle down.
All thanks to rust and the climate
Unread 02-08-2016, 07:36 AM   #14
riot1987
Didnt know that. Ive beat the **** outta those things... Ill think of that next time.
Build thread^^
