cant get antenna mast to pull in - JeepForum.com
post #1 of 22 Old 02-05-2008, 06:16 PM Thread Starter
a70eliminator
it pulled out easy enough just can't get the motor to pick up the teeth and pull it back in.
I pulled it out to give it a good cleaning for it was getting a little sticky, it now works way smoother by hand, I should have payed a little closer attention to how the teeth were oriented. Can anyone give me a hint on getting it back operation? Thanks.
a70eliminator is offline
post #2 of 22 Old 02-05-2008, 06:40 PM
driabyor
driabyor's Avatar
1994 ZJ
probably stripped the teeth on it... as it's just plastic
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 22 Old 02-05-2008, 06:47 PM Thread Starter
a70eliminator
No man the teeth are perfect, the thing worked it was just a little sticky, screw it I'll get to go back in it's just raining like crazy and it got dark on me, I'll give up for the night and tomorrow it'l slip right in.
post #4 of 22 Old 02-05-2008, 06:47 PM
kmd1776
what you have to do is start feeding it in by hand, and have someone else turn the car on then off. and supposivly itll go all the way in the 3rd or 4th time. thats what the dealership told me at least when i bought my new one.
unfortunatly i cant get my original one out at all. it seems to be stuck in there. you know any tricks of getting it out??
kmd1776 is offline
post #5 of 22 Old 02-05-2008, 07:09 PM Thread Starter
a70eliminator
No problem
just stand at the passengers door with one hand on the tip of the antenna and with the other hand reach in and hit radio power button and pull the mast out, now if the motor doesn't run your screwed.
post #6 of 22 Old 02-05-2008, 08:12 PM
kmd1776
no it runs, i hear it everytime i start the car. i do have an alpine aftermarket deck (came with the car). now when i take that little chrome nut off, i have my friend go in and turn the electrics on in the car, the motor kicks in, and i try pulling it out and it just wont budge at all. i dont know if it wont come out because i have an aftermarket deck, even though i hear the motor running, or if its jammed somehow. anyway of getting into the motor itself to find out? or better yet, convert to a standard antenna??
kmd1776 is offline
post #7 of 22 Old 02-05-2008, 08:15 PM
alivenkickin28
If you are trying to put it back in....all you have to do is hold the antenna and put the plastic regulator thing in the antenna hole....just push it in until it stops on its own...have the key turned but not to start the engine.. have the radio on so that the motor "goes up" then turn it off so that it "goes down" it may take a few times and you may have to turn the plastic regulator a different way but eventually it will pull it in...make sure that you have the retainer a well so that when it goes down completely it locks it in place and you can put the escutheon over it.....
to get it out...even if your motor isnt reponding...it should pull out by hand...the motor will rotate even if its burned up....only way it will not is if the plastic gears inside the motor are busted...it could be jammed....go to the junkyard and grab ya one!
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #8 of 22 Old 02-05-2008, 09:00 PM
kmd1776
thats what i wanted to do, grab 1 from a junkyard, but do you know how to take the actual motor out or at least where its located? looked around and couldnt seem to find it.
kmd1776 is offline
post #9 of 22 Old 02-05-2008, 09:19 PM
driabyor
driabyor's Avatar
1994 ZJ
in the right fender LOL..... remove plastic fender liner... or at least enuf to get at motor
5.2 liter 242 :)
driabyor is offline
post #10 of 22 Old 02-05-2008, 09:20 PM
driabyor
driabyor's Avatar
1994 ZJ
right under the place where it goes down
5.2 liter 242 :)
driabyor is offline
post #11 of 22 Old 02-05-2008, 09:50 PM
kmd1776
hahah thats what i was afraid of, doesnt look too easy to get to. now how hard is it to scrap the whole motor and just put a standard antenna in its place?
kmd1776 is offline
post #12 of 22 Old 02-05-2008, 10:07 PM
alivenkickin28
OMG dont hack the jeep....its not that hard to change out the motor...the space is a little tight but its only an hour job if that!
post #13 of 22 Old 02-05-2008, 10:14 PM
kmd1776
alright ill go out and take another look. but again is it possible to just convert it to a standard antenna? or is this not possible
kmd1776 is offline
post #14 of 22 Old 02-05-2008, 10:48 PM
driabyor
driabyor's Avatar
1994 ZJ
yes you can use a plain antenna. I you want ,drill another hole install regular antenna . leave the old one where it at..... run the wire thru the door opening.
or remove the old power antenna and replace with a new non motorized one. the plastic fender has a few screw or faseners of somekind. plus the motor is bolted in, you will also have to remove the inside kick panel to gain access to the wiring
Mine been non moving for several years .I just pulled it up and left it... radio plays. The motor makes a noise whn i turn it off an on.... radio works ....
5.2 liter 242 :)
driabyor is offline
post #15 of 22 Old 02-05-2008, 11:19 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It is sooooo tempting to make a comment:
Okay, does the antenna retract after the song is over? Was it a long song or just a quick one?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
ZJ Electric Antenna Mast Replacement Tyrefryer ZJ Grand Cherokee Forum 11 08-22-2013 05:20 AM
Need solid mast antenna Baldman902 ZJ Grand Cherokee Forum 4 12-10-2009 04:03 PM
Antenne Mast wont go up, and can only pick up AM. bravo09 ZJ Grand Cherokee Forum 2 11-17-2008 11:52 PM
antenna mast replacecment alivenkickin28 ZJ Grand Cherokee Forum 5 02-14-2007 09:38 PM
Replacement power antenna mast? MAUSS ZJ Grand Cherokee Forum 19 11-16-2005 08:34 PM
