Can you mount lights on the stock bumper cover?
#1 | |
- Hi, I was wondering if i could mount a couple driving lights on stock bumper cover. Or, would it be too shaky and unstable to work any good? If anyone has done this could you post up some pics. Thanks
#2 |
mount some metal angle brackets to the metal "bumper" under the cover, and then mount the lights to those
1995 GC 4.0 231 |
#3 |
I forgot where I saw pictures of that, but basically they made metal tabs that attached to the metal bumper and drilled a hole though the plastic bumper cover and mounted the lights, worked fine.
#4 | |||
I posted this in a thread a few pages back...
http://www.jeepforum.com/forum/f13/driving-lights-help-choice-them-485050/ Quote:
David. 94 ZJ laredo 5.2 V8 soon to be 5.9!! In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden |
#5 |
Very nice switch setup.
Still, the question is about mounting the lamps themselves. Bracket them to a solid mouniting grab em twist em
DD: 98 ZJ Laredo 5.2, all stock Wheeler/Beater: 93 ZJ Laredo 4.0, AW4, 231 conversion from 249 3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard Colorado Jeep Club Member 242 (4.0L) |
#6 |
I guess you skipped over some of that.. I didnt use the "L" bracket works just fine in the plastic bumper with no vibrations. But the OP has a WJ so he might need a different set up.
#7 |
mine are just bolted to the plastic.... see my teeny tiny avatar
94 Grand Cherokee ... 332,000 miles 5.2 liter 242 :) Rancho 5000 steering stabilizer |
#8 |
oh two on top and two on the bottom
#9 |
Mine are on brackets that bolt down under the grille. I don't remember if this is how the stock fog lights came or not, but thats how they're mounted. The bracket looks like a flattened, elongated Z from the side, and there are two cutouts from the bumper cover to allow them to poke though. I'll get some pictures tomorrow.
#10 |
i hear of a lot of people that put down a strip of metal down under the plastic like 1/8 - 1/4" thick and then mount the lights through there. you just have to carve out some of the foam.
#11 |
Jeep Jedi Master
The answer is yes, it can be done. BTW, you got lots of great ideas on this thread to help.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#12 |
![]() ![]() thats how i mounted mine. I guess those were the factory fog light mounts..i had to cut them up a little to fit them suckers on there but they are stable as a rock..the brackets that they bolt to are tied into the header panel....so the only way them lights are commin off it to be unbolted or for the header panel to get ripped up.
Dylan-19 and Yearning 93 Rubigrand - Sold... :'( 95 Grand Cherokee Limited - 5.2 Mall Crawler 55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders.... |
#13 | |
I'm no member of The Lumentist Society, but I am a thinker... ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
