Can you help me get her ship shape? - Page 2 - JeepForum.com
post #16 of 23 Old 01-29-2013, 01:11 PM
JS97ZJ
The I6 isn't any party either, but some of the guys here have been able to get it replace by tackling at a certain angle.
Maybe be someone the 5.2 can describe it or you might be able to give it a search.
JS97ZJ is offline
post #17 of 23 Old 01-29-2013, 02:45 PM
hezx
to get mine out of the 4.0 I had to get 2 feet worth of extensions just to have enough room to turn the ratchet
hezx is offline
post #18 of 23 Old 01-29-2013, 02:47 PM
hezx
btw..... do not put bosch plugs in ZJ's... only champion or autolite coppers
hezx is offline
post #19 of 23 Old 01-29-2013, 02:59 PM Thread Starter
Solaris17
You got it guys next pay check or so I'll yank them.
Solaris17 is offline
post #20 of 23 Old 02-06-2013, 10:16 AM
massarosareloud
To fix your flickering interior lights, I would spray some contact cleaner into the slider switch. Take the entire headlamp switch assembly out of the dash, take the circuit board out of the assembly, and spray the contact cleaner *directly* into the potentiometer. You need to remove the entire assembly from the car because there is a dust shield you need to get the contact cleaner straw under. Work it up and down a few times and that should help too. While you have it out DEFINITELY reflow all the solder points and add solder where it is needed.
1996 Jeep Grand Cherokee Limited Edition 4.0L
3.55 axles, stock pretty much everything, except for a PSC steering gear and fuel injectors
massarosareloud is offline
post #21 of 23 Old 03-06-2013, 02:24 PM Thread Starter
Solaris17
Bumping for your enjoyment
I re soldered the headlight unit and Vic and both are ship shape
The stalling I eventually tracked down the cat was clogged it was replaced and it never happened again
The brake issue is infact the calipers and I will replace the whole system in a few months since I have already rebuilt these once.
The bang I never got sorted but I will spend more time on it now that she is running right.
In the process I made a new intake
Replaced some gaskets
Replaced TPS and crank position
Thank you all for the help she is exactly 200 miles away from 200k I'll bump with a pic
Thanks for helping me get her that far!
post #22 of 23 Old 12-02-2013, 04:41 PM
LynF
I downloaded the manual from the link, it is supposed top be for 93-98 it is for the 96zj? anyone wanna trade? i pd for it bur if it isnt the right year it isnt going to do me any good. e mail me or pm here
Lyn
LynF is offline
post #23 of 23 Old 12-03-2013, 07:00 PM
Higgins
I have a 1998 Jeep Cherokee FSM if anyone is looking for one. Just PM ME!
AL
Higgins is offline
