Can't seem to get my steering stabilizer off - JeepForum.com
post #1 of 10 Old 08-22-2009, 08:22 AM Thread Starter
gangstamedic
Hey guys,
I just bought a ew OME steering stabilizer to put on my 97 GC Laredo 4.0. I cant get the old one off due to one of the bolts being stuck. Any help with this problem would be great. this 15min job has turned in to a 2 hour fiasco. I dont know if it is just kept on by the nut or if its screwed on. Its attached to the steering brace, on the bottom. thanks
Ray
gangstamedic is offline
post #2 of 10 Old 08-22-2009, 08:32 AM
RyanSBenson
Did you try hitting it with some penetrating oil? Soak it with something like PB blaster and then try again.
01' WJ Laredo Stock
96' XJ Sold
RyanSBenson is offline
post #3 of 10 Old 08-22-2009, 08:36 AM
WhiteOut
WhiteOut's Avatar
Penetrating oil, heat, breaker bar
WhiteOut is offline
post #4 of 10 Old 08-22-2009, 08:38 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Soak it with penetrating oil (WD-40 or similar).
Or heat it up with a torch (but not right after applying the penn oil).
Use a bigger wrench.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 10 Old 08-22-2009, 08:51 AM
ZooTech
I had to grind off the nut and push the bolt out of the hole with a 2-jaw puller rented from AutoZone.
~ 1995 ZJ
~ np242
~ 2.25" BB
~ Rough Country Nitro 9000 shocks
~ 31x10.5x15 Dunlop Radial Mud Rovers
~ 15x8 black Unique wheels
ZooTech is offline
post #6 of 10 Old 08-22-2009, 09:05 AM
SaturnICL
Dont know if it is the same but the nut on the WJ SS is spot welded on so you only turn the bolt. You can put a wrench on it but all you will get is a workout and a headache.
SaturnICL is offline
post #7 of 10 Old 08-22-2009, 09:09 AM
JrMechanic
I couldn't get mine out. Heat, PB blaster, BFH, pullers, etc. It would not budge. I just left the stud in there.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #8 of 10 Old 08-22-2009, 10:42 AM
kentman
kentman's Avatar
2006 XK Commander
Pitman arm puller. It was the only thing that worked on my old ZJ SS. They are like $15 at Harbor Freight.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #9 of 10 Old 08-22-2009, 11:01 AM
squashman702
1994 ZJ
2 jaw puller . . . put pressure on the bolt, then hit the drag link with a small sledge next to where the bolt is. It should pop right out.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #10 of 10 Old 08-23-2009, 09:09 AM Thread Starter
gangstamedic
thanks guys, I got it out used a big *** hammer and some Big ****'s Super LUbe. If you have never heard of it..google it, it is the best stuff for everything...period
should I get a steering stabilizer? gharris54 ZJ Grand Cherokee Forum 5 11-22-2009 08:59 PM
Best steering stabilizer? jeepgc99lmtd ZJ Grand Cherokee Forum 22 11-20-2009 01:54 PM
Steering Stabilizer YERFDOG ZJ Grand Cherokee Forum 8 10-01-2009 10:42 PM
Steering Stabilizer Windowsrookie ZJ Grand Cherokee Forum 52 05-31-2008 11:34 AM
Steering Stabilizer Q ben_wagner ZJ Grand Cherokee Forum 6 08-06-2006 08:15 PM
