Can't Find a ZJ Interior Fuse Diagram ! - JeepForum.com
post #1 of 7 Old 04-10-2010, 04:14 PM Thread Starter
CHandy70
I just got a beautiful 1997 ZJ 5.2 Limited with 207k Miles!
( Pics to come )
I will be owning this car till it dies one day I would like to have a copy of the fuses. Any luck from anyone! I have done lots of searchign and this is all i have found.
My #17 does not light up.
Side note:
Just recently when my friend shut the Front Passanger door the Fan Motor just cut out! So i'm trying to trouble shoot that as well.
The Fan is getting power but i don't yet have a way to power up the fan separately to see if it runs on its own. I have the Auto Switches.. Do the switches burn out?
Thanks,
Chuck III
Aim Chandy70
Chandy70@gmail.com
CHandy70 is offline
post #2 of 7 Old 04-10-2010, 06:23 PM
jp88
If you have the automatic temp control like I think you probably do, The fan control module feeds the fan on all speeds but high and the fan control relay feeds the fan on high. They both get power from a 40 amp maxi fuse in the fuse panel under the hood.
However if the fan is getting power and is not running the fan motor is most likely bad.
96 zj 5.2l v8 stock
jp88 is offline
post #3 of 7 Old 04-10-2010, 09:04 PM Thread Starter
CHandy70
So I checked all the fuses in the car everything is okay even the ones i thought were bad are okay. Under the hood and in the car.
I unplugged the fan motor and the power to the fan is there I'm only able to check it with a check light not a multi meter. I got an extra car battery and i hooked it up to the fan and i got the fan to spin too!
So could it be the switch? or the fan is gone? Very confusing..
CHandy70 is offline
post #4 of 7 Old 04-10-2010, 09:24 PM
Falkon
Falkon is offline
post #5 of 7 Old 04-10-2010, 09:30 PM Thread Starter
CHandy70
^^^ Yeah that is not it!
CHandy70 is offline
post #6 of 7 Old 04-10-2010, 11:20 PM
jp88
Did you check for ground in the plug as well as hot?
96 zj 5.2l v8 stock
jp88 is offline
post #7 of 7 Old 06-14-2010, 09:10 AM
Antdagoon
Fuse Diagram
The fuse panel diagram is in the owners manual. I bought one for $3.50 on ebay. They really should have included it on the fuse panel cover, dont you think?
Antdagoon is offline
diagram , fuses , grand cherokee , jeep
1994, 5.2L cherokee Fuse panel diagram.. giggityjeeper ZJ Grand Cherokee Forum 2 08-31-2009 01:29 PM
fuse diagram j33p0104 ZJ Grand Cherokee Forum 4 02-24-2009 03:13 PM
Fuse Panel diagram 1994 Laredo Jon08JK ZJ Grand Cherokee Forum 4 01-09-2008 01:08 AM
blown fuse replacement, is there a diagram? duscrapiron ZJ Grand Cherokee Forum 18 04-23-2006 01:42 PM
93 Fuse Diagram Jami ZJ Grand Cherokee Forum 5 10-20-2003 01:23 PM
