Can somebody tell me what this - JeepForum.com
post #1 of 8 Old 09-28-2013, 08:20 PM Thread Starter
Jeepdrifkid1996
I am talking about the cord that running from the valve cover to the air filter i broke yesterday while changing the valve cover gasket its held on buy electrical tape but that wont last. Does anybody know what it is and where i can get it? Oh and i have zj grand cherokee Laredo with a 4.0l engine if that helps sorry first post so bear with me
Jeepdrifkid1996 is offline
post #2 of 8 Old 09-28-2013, 08:33 PM
xcaliber81
CCV, front is a 90 elbow rear has a 1/8 id may as well do both and replace the grommets may be dodge only dont worry they are fairly cheap. Try Not breaking them as they are fairly hard to remove its a pita to remove the valve cover.
xcaliber81 is offline
post #3 of 8 Old 09-28-2013, 08:33 PM
ZeeJay1997
Yes that is your CCV TUBE and FITTING ASSEMBLY, w/o Orifice , part number 53030497.
It is a PITA to get out. You run a chance of busting it when you try to get it out. Be sure none of the pieces drop into the valve train. If they do, you will need to pull the cover. If you pull the cover, you will probably break the one on the back. It's not the same thing. it's a 53030495 TUBE and FITTING ASSEMBLY, w/Orifice
the grommets are 2946 079
ZeeJay1997 is offline
post #4 of 8 Old 09-28-2013, 08:44 PM Thread Starter
Jeepdrifkid1996
Ok thanks guys much appreciated.
post #5 of 8 Old 09-30-2013, 02:26 AM
firehawk1
Dorman actually makes both elbows now
Front # 47079
Rear #47057
Grommet# 42344
firehawk1 is offline
post #6 of 8 Old 09-30-2013, 06:12 AM
V65Ozzie
All available at advance auto, but may not be a stocking item. Last one I got was a next day item.
Retreat? Hell, we just got here......
V65Ozzie is offline
post #7 of 8 Old 09-30-2013, 09:10 AM
SDHarleydad
1994 ZJ
I cracked mine... I used JB weld to fix it.
Casper
1994 JGC Laredo
SDHarleydad is offline
post #8 of 8 Old 09-30-2013, 09:57 AM
mckellyb
Good man!
JB Weld fixes pretty much anything, at least for a while.
Between it, zip ties, and some two-part epoxy, you're covered for anything but a broken connecting rod.
/humor
White '98 5.9L as a dedicated towed car, 175K miles, bone stock
2008 LS 460L, my DD
mckellyb is offline
