Can some one tell me about front rotors? - Page 2 - JeepForum.com
post #16 of 17 Old 04-14-2011, 01:29 PM
speedbucket
Originally Posted by doomi View Post
Not always, two of mine were nearly fused to the hub... not that it makes it any more difficult. Soak with a penetrating spray and beat the crap out of the old rotor until it falls off and you are good to go.
i make sure to knock mine loose every time i rotate the tires.
also, get 2 hammers if its seized to hub and hold one on the inside of the rotor (same side as your hitting but acroos the rotor. ex:2oclock and hit it at 8oclock). this also works well on pitman arms
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #17 of 17 Old 04-14-2011, 04:30 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Most problems with ZJ brakes stem from notches in the sliders. Usually mistaken for bad calipers. But calipers rarely ever fail.
Keeps the varmints on the run, boy
HighLonesome is offline
Rotors - front and rear Knoxes ZJ Grand Cherokee Forum 1 08-07-2009 12:15 PM
Front Rotors UTChavok ZJ Grand Cherokee Forum 9 07-09-2008 11:13 AM
96 front rotors jeeptorino68 ZJ Grand Cherokee Forum 8 06-27-2006 08:20 PM
Front rotors alan111 ZJ Grand Cherokee Forum 2 05-24-2006 09:14 PM
How remove front rotors? hinchcliffe ZJ Grand Cherokee Forum 12 10-18-2005 02:38 PM
