Can some one tell me about front rotors? - JeepForum.com
post #1 of 17 Old 04-12-2011, 04:48 PM Thread Starter
jeeponthebeach
I just brought my 1995 5.2 Orvis in to Midas because I'm getting some shuddering when I brake and I can hear a rubbing sound coming from the brakes. They wanted over a $1000 to do the job and $560 to do just the front. I can't afford that so I'm gona have a buddy help me out. Is there any brake issue nightmares that I need to know about on the 95s? My friend is concerned we may need special tools to get the rotors off especially the front because of the 4wd hubs and everything. I guess Im gona do new rotors calipers and pads all the way around. Anything else I need to worry about or should know when doing a brake job on a 1995 awd 5.2L Jeep. Any help would be greatly appreciated.
edit: Also how do I find out whether the calipers I have are Phenolic or metal? thanks
jeeponthebeach is offline
post #2 of 17 Old 04-12-2011, 05:11 PM
ZJ5point2GCL
Holy crap thats allot.
but your in luck, a brake job doesn't get any easier than on our jeeps, all you need to do it, take off the wheel, un bolt the calliper just a standard 15mm i believe, push the piston back in, stick the new pads in, slide off the old rotor, make sure you clean the new rotor well before you slide it on, bolt the calliper back on, and then put the wheel on.
Rotors will run about 70 each and another 70 ish for good pads.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #3 of 17 Old 04-12-2011, 05:21 PM
Foundrydude
Ummm, you do know Midas is the #1 chain for price gouging.....dontcha? Does not matter if you're in boise or miami, it's $1000-2500 to drive any car out of a Midas if the problem has anything to do with brakes or a front end rebuild. They are FAMOUS for making a $300 problem into a total frontend rebuild or total brake system replacement.
Foundrydude is offline
post #4 of 17 Old 04-12-2011, 05:21 PM
KingtheZJ
this is right on. its a REALLY easy job. the caliper bolt is a 13mm if factory. use something like a small piece of wood, or the old pad to protect the piston and use a c clamp to compress it and force the fluid back in. this will allow the new pads (more material and fatter) to clear the rotor.
i rebuild my entire front end brake parts for about 180.
40 per rotor
35 per caliper
30 for pads
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #5 of 17 Old 04-12-2011, 05:26 PM Thread Starter
jeeponthebeach
Thanks a lot guys. I nearly crapped my pants when they told me the price. Luckily I had a free inspection coupon. I think I'm just going to do the fronts first. So no special tools to take off the front wheel rotors even though is AWD? I could tell my friend was willing to help if it was going to be relatively easy. He sounded vary wary of all kinds of difficulties dealing with the full time 4wd components though. I guess the phenolic piston calipers were oem and metal are optional?
post #6 of 17 Old 04-12-2011, 05:53 PM
Foundrydude
There is nothing special about the awd when it comes to brakes. Same exact method of replacement as the average front wheel drive econocar.
post #7 of 17 Old 04-12-2011, 06:49 PM
KingtheZJ
no special tools at all. everything you need is lug wrench, 13mm socket or wrench, c clamp, screwdriver to get the pads out. thats it
when you take off the wheel and caliper the rotor will literally fall off. its held against the hub on by the wheel.
'88 XJ
post #8 of 17 Old 04-12-2011, 07:43 PM
Technohead
Don't cut corners on the pads. Buy top of the line such as Hawk HPS. They make a huge difference in braking power. Stock rotors can be had for $50 or even less. Calipers can usually be re-used but they can also be had for like $30 after returning your old ones for the core charge.
-Eric
Technohead is offline
post #9 of 17 Old 04-12-2011, 08:20 PM
SAR-Swimmer
Brakes are one of the easier repairs to do yourself. You might want to invest in a Haynes Manual; they're fairly cheap ($ 20-30), explain a lot, and even if you decide to let a shop do the repairs, you'll have a idea what's involved, so you don't get hosed.
SAR-Swimmer is offline
post #10 of 17 Old 04-12-2011, 11:19 PM
Pugulis
If you've never worked on a car before, this is a great place to start. Get a Haynes manual and go to town. It's one of the simplest things to do. A grand for a brake job!!! I've heard they grow some good stuff in Hawaii. But, Dam, what have these guys been smoking! I don't care if you have to replace everything. After doing it yourself, I'd contact your local Better Business Bureau and report them.
Pugulis is offline
post #11 of 17 Old 04-12-2011, 11:26 PM
ZJ5point2GCL
you should also get some brake fluid test strips, to make sure your fluid is still usable.
and if not its also pretty easy to change out.
as someone said, you could always get a haynes, its a really straight forward job, but it might give you more confidence having the step by step and pictures.
post #12 of 17 Old 04-12-2011, 11:37 PM
Pugulis
Also, just to show you how much Midas rips people off. About 10 years ago, my friend took his wrangler to fix an exhaust leak (the pipe to the header needed to get welded). The job was only going to cost 100 bucks. That didn't seem bad. While they had the Jeep, they called him and asked if he wanted them to do the cap rotor and wires. He told them he'd have to call them back. Then he called me and asked if the price they quoted sounded like allot. Well, it was. They wanted 145 dollars for the cap rotor and wires. Mind you, that's not installed. That's just the cost of the parts. He called them right back and told them he didn't want it done. They then tried to claim he said to do it. He argued with them and they agreed to just charge him labor (as they already threw out the old parts). I drove him to pick it up and when we popped the hood, the old wires were on. Went back inside and they claimed that it was a mistake and the guy behind the desk only thought it was already done. After giving him a refund we headed out. The next day, the pipe they were supposed to have fixed, fell off! They didn't weld anything, they just put a clamp on it. Had to take it back again. This time we both sat and watched them weld it up. I will never go to, or suggest anyone else go to Midas. Midas; Morons, Idiots, Dumb As Suckers.
Pugulis is offline
post #13 of 17 Old 04-13-2011, 07:39 AM
melk
Do it yourself. Very easy as everyone had said and it's a great project to learn and build confidence in your skills.
Don't buy cheap pads. HUGE difference when you shell out a few extra bucks for the good stuff.
melk is offline
post #14 of 17 Old 04-13-2011, 05:02 PM Thread Starter
jeeponthebeach
Thanks for all the replies guys. I'm defiantly gona give this a shot. I never really worked on brakes and didn't want to mess anything up. I have a chiltons manual but it's not the clearest thing to understand and everyone on here always recommends the Haynes so I'll probably pick one up. I found rotors for around $40 and I was going to just get the cheapest pads available but now I think I'll get the metal ceramic ones that were a bit more pricey. Thanks again guys.
post #15 of 17 Old 04-14-2011, 11:43 AM
doomi
Not always, two of mine were nearly fused to the hub... not that it makes it any more difficult. Soak with a penetrating spray and beat the crap out of the old rotor until it falls off and you are good to go.
doomi is offline
Rotors - front and rear Knoxes ZJ Grand Cherokee Forum 1 08-07-2009 11:15 AM
Front Rotors UTChavok ZJ Grand Cherokee Forum 9 07-09-2008 10:13 AM
96 front rotors jeeptorino68 ZJ Grand Cherokee Forum 8 06-27-2006 07:20 PM
Front rotors alan111 ZJ Grand Cherokee Forum 2 05-24-2006 08:14 PM
How remove front rotors? hinchcliffe ZJ Grand Cherokee Forum 12 10-18-2005 01:38 PM
