Can Idling Cause Over-Heating? - JeepForum.com
post #1 of 5 Old 10-01-2003, 10:33 PM Thread Starter
bighead113
Since tonight was a very cold night, I went to go pick up a friend and me and my gf had both heated seats on, the rear defroster on, and the front defroster on high, and we had to wait there in idle for about 25-30 minutes, then the "check guages" light came on, and it overheated, with smoke pouring out, and the coolant boiling....
So, I guess my question, is, what is my best option?
1. Take the truck in to the shop immediately (it has a warranty)
2. Fill up lost coolant, take truck in Saturday (when I have more time)
3. Re-fill, dont worry about it, and dont let it see in idle that long again?
Thanks...
bighead113 is offline
post #2 of 5 Old 10-02-2003, 12:19 AM
whitevette
whitevette's Avatar
Your cooling system is tired and worn down. You should be able to idle until you run out of gas and not experience any overheating.
Take it to a shop. Make sure they flow test your radiator. I'd bet it's clogged from old coolant letting it rust internally and clog.
Darkness is deaths ignorance, and the Devils time.
'96 Grand Cherokee Laredo
'93 Taurus SHO
'77 Corvette L-48
'74 Land Cruiser FJ40
whitevette is offline
post #3 of 5 Old 10-02-2003, 05:16 AM
93JGCV8
also you might want to check out your fan clutch if the overheating problem is only at idle.
93JGCV8 is offline
post #4 of 5 Old 10-02-2003, 05:46 AM
Harald
Thanks...
You will probably hear noise from a defect fan clutch, and they tend to get jamed when worn out. As suggested, the engine should be able to run for weeks on idle without overheating. If you have an I6, then you should have (at least in Europe) two fans, where one is driven by electric motor. The thermostate engaging this motor can fail, or bad el. connectin makes it fail. Fill up system as required with proper coolant. Warranty? Go to dealer on Saturday, and don't run on idle until then. V8? Belt driven fan via clutch on 5,8L. Aslo clogged radiator a very possible reason. Again, something that should be a warranty issue.
Harald is offline
post #5 of 5 Old 10-06-2003, 11:01 PM
jeepjeepers
Had the same problem awhile ago and the dealer replaced the fan clutch. Haven't had any problems since.
jeepjeepers is offline
Idling ? xbucux ZJ Grand Cherokee Forum 1 05-27-2009 08:04 PM
Idling at 600 rpm billy mo ZJ Grand Cherokee Forum 1 05-14-2007 11:42 AM
Seat heating does not work, but heating elements are ok WolfgangK ZJ Grand Cherokee Forum 12 04-17-2006 10:44 AM
WJ 4.7 V8 Not Idling Well jet190rs ZJ Grand Cherokee Forum 3 04-25-2005 02:26 PM
Idling to low Jeepster94 ZJ Grand Cherokee Forum 2 08-04-2004 10:19 PM
