Can I use a v8 DS CV on an I6 DS? - JeepForum.com
post #1 of 4 Old 05-24-2011, 07:08 PM Thread Starter
Iamlew
Bought a driveshaft out of a v8 zj of the same year (93) it's too long and thinner (less diameter)
The CV on mine is completely shot, curious if I can just pull the universals and swap the CV's. They look the same.
If not I'll have to bus back to the junkyard and swap it out lol.
Iamlew is offline
post #2 of 4 Old 05-25-2011, 06:49 AM
newfieZJ
By CV , I have to assume you mean the double-cardon joint , towards the t-case ? I say this as the 93's don't use a CV style front DS , Late 95 and up V8's do .
At which point I say , yes , all the universals will exchange . Note the pinion side universal is different from the 2 in the double cardon joint (referenced parts list). While in there , check and grease the ball centering joint .
newfieZJ is offline
post #3 of 4 Old 05-25-2011, 11:55 AM Thread Starter
Iamlew
Yeah I totally meant the double cardigan lol.
I'm having trouble removing mine for some reason. My ball joint in there is what's shot, it's completely separated and there is a bunch of bent/shiny metal.
Iamlew is offline
post #4 of 4 Old 05-25-2011, 12:02 PM
speedbucket
1. its not a sweater Daniel Tosh would wear
2. i used the same ujoints (5) for everything with no problems
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
