Can I Take Out The Infinity Amp? - JeepForum.com
post #1 of 14 Old 12-23-2013, 02:47 PM Thread Starter
supzack
I have a 1997 Jeep Grand Cherokee and people have told me that I cannot touch the Infinity amp because I will have a lot of trouble with wiring and I was wondering if I could just get rid of all the speakers and use new ones. I have the Infinity speakers in the font and different speakers in the rear and a different head unit a JVC KD-R520. I want to put in subs and put in Kenwood KFC-G1620 speakers. Would I just have to rewire them to the head unit? Does anyone know if I will have other electrical issues? I just want to know if its as simple as rewiring the speakers.
supzack is offline
post #2 of 14 Old 12-23-2013, 03:05 PM
bcbueller
yes you can ,i have a 98 ltd and the amp is under the passenger seat on the drivers side . you CAN reuse the stock wire for the speakers (high level) in and out of the amp but can create engine noise . or rewire the whole with RCA wires and then new wires to the speakers new or stock . Try to dynamat the doors it will make the sound tighten up substantially. I currently have a JBL 5 channel amp under the drivers rear seat with sub in the back and all new speakers. coaxial 6.5 for the rears mid tweet components 6.5 set in the front doors and another set of tweets in the stock dash location
Just a Bueller
bcbueller is offline
post #3 of 14 Old 12-23-2013, 06:27 PM
Winger67
Pin out of the amp connectors. http://crutchfield.custhelp.com/app/...tail/a_id/5764
I've seen people just jumper the connector to bypass the factory amp using solid wire jumpers. I have a Kenwood head unit running through the factory amp on my '96. I want to try bypassing the factory amp to see if it makes any difference but so far I haven't had any problems.
Winger67 is offline
post #4 of 14 Old 12-23-2013, 10:48 PM
T-nave
Why take out the factory amp? Is it broke? I replaced almost all my speakers and wired in a second amp to power my sub and back door speakers. Its not the loudest in my neighbor hood but it bangs pretty good and is plenty loud enough. Plus it was simple as hell.
9er, 3.5 IRO lift + 3/4" spacers w/ adjustable trac bars and arms, 242 swap, 285/70/17 Duratracs and some other doo dads
T-nave is offline
post #5 of 14 Old 12-24-2013, 09:42 AM
mig1289
Yes. When I redid my Jeeps sounds system I didn't trust the stock writing at 1000w. I ran all new heavy gauge wiring just to make sure everything was done right. Not a bad job, just a pain getting it through the door jams
2wd zj...
mig1289 is offline
post #6 of 14 Old 12-24-2013, 04:58 PM
Gearhead31
You can rip it out and burn that hunk of scrap if ya truly want but then you'll have to re-run wiring from the radio cubby out to the doors and that will be a fair bit of a PITA to do. I never wanted to bother with that nightmare so I just re-used it. Sounds more than good enough for me, the only limiting factors are the aftermarket speakers rattle.. I need to get the door bass boxes and better speakers, maybe some soundproofing liners as well to finish it up.
Of course if your factory amp is dead, that's another story.. If it were me, I'd just see about replacing it with a junkyard grab(if you could test it to make sure it's good that is)
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #7 of 14 Old 12-24-2013, 11:11 PM
Pugulis
In my experience, once you go aftermarket, go all the way. If you're going to put in a new HU and speakers, you might as well re-wire. You don't want to spend the time and money installing a new HU and speakers only to have it sound like crap because of faulty 15+ year old wiring. As far as the amp, it's not really needed with a new system. And if your going to spend money on a new HU, speakers, sub, why not just get a new amp as well?
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline
post #8 of 14 Old 12-25-2013, 01:34 PM
Gearhead31
Wise advice pugulis
post #9 of 14 Old 12-25-2013, 02:45 PM
Caelanderby088
You can remove the Infinity amp. I own a 95 Zj Limited 318 and the amp caused my complete system to fail. Took it to the shop they ripped out the amp and added a bunch of wiring.
Caelanderby088 is offline
post #10 of 14 Old 01-25-2014, 04:07 PM
zleehw
rremove amp
can I remove the amp...unpin the wires from the plugs and then connect the appropriate wires to each other....
I am using a inline alpine amp that plugs into the radio and then into the vehicle connectors under the dash....so I don't need the infinity amp under the rear seat.
so I am asking if I unplug the in connector to the amp and unplug the out connector to the amp can I use jumpers or strip and crimp new connectors to get the infinity amp out of line?
zleehw
zleehw is offline
post #11 of 14 Old 01-26-2014, 08:40 AM
50notch
Yes you can.
1998 Grand Cherokee 5.9 - DT headers, Kolak 3" exhaust, 2" BB, K&N CAI
50notch is offline
post #12 of 14 Old 01-26-2014, 10:27 AM
MRKeasal2010
I bypassed it by rewiring the speakers to my aftermarket player. I attached the new speaker cable to the corresponding wires on the harness adapter. Works like a charm! I imagine you could wire in your in line amp in much the same way. It'd save you the headache of going through the amp wiring (like I attempted to do).
MRKeasal2010 is offline
post #13 of 14 Old 01-26-2014, 10:57 AM
zleehw
I found this today - Metra 70-6513 Amplifier Bypass - no cutting, just unplug amp and plug in this abd bam all done. Then I can place my alpine inline dash amp and done.
zleehw
zleehw is offline
post #14 of 14 Old 01-26-2014, 10:58 AM
zleehw
Metra 70-6513 jeep grand cherokee 1994-1996 amp bypass wiring harness
zleehw
zleehw is offline
