can I stroke the 5.2 to a 5.9 ??? - JeepForum.com
post #1 of 22 Old 01-31-2013, 05:21 PM Thread Starter
gerardines
1990 XJ Cherokee
I'm planning on stroke the 5.2 adding the rebuild master kit of a 5.9 from titan engines.
Wath should I do to get it right, is it even possible ?????
Need an answer soon 'cause i'm buying the kit next week.
thanks,
1990 Cherokee 4.0 2.5'' lift Fox 2.0 shocks 30*9.5 Maxxis Trepador
gerardines is offline
post #2 of 22 Old 01-31-2013, 07:57 PM
slate98ZJ5Niner
if you want to stroke a 5.2 get this.
http://www.hughesengines.com/Index/p...=&partid=25284
slate98ZJ5Niner is offline
post #3 of 22 Old 01-31-2013, 08:08 PM
dusterdude
No
dusterdude is offline
post #4 of 22 Old 02-01-2013, 05:48 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Or, spend less money on a 5.9 create motor with 325 or more HP.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 22 Old 02-01-2013, 07:57 AM
slate98ZJ5Niner
Ya I don't know how a $10,000 crate motor is going to be cheaper than a stroker kit.
http://www.moparproshop.com/inc/sdetail/4515
http://www.jimsautoparts.com/mopar_p...ce_engines.htm
http://www.jegs.com/i/Mopar+Performa...FUWnPAodpwQA_g
http://compare.ebay.com/like/3104063...Types&var=sbar
post #6 of 22 Old 02-01-2013, 09:31 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
2,300.00?
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 22 Old 02-01-2013, 09:32 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Pull your old one , put accessories on this one, plug in.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #8 of 22 Old 02-01-2013, 10:34 AM Thread Starter
gerardines
1990 XJ Cherokee
I'm planning on getting more torque from the 5.2 now that it's open 'cause it got sand inside ... so if it's going to be on 0.20 why not gettin it up to a 5.9 with the master kit.
the 5.2 has already d44 in rear, but i know that the 5.9 came with a stronger transfer case.
post #9 of 22 Old 02-01-2013, 01:07 PM
BigJohn96ZJ
Im pretty sure the transfer case is the same only the trans is stronger. 46re in 5.9
44re in 5.2
96 ZJ Laredo 4x4, 5.2l, 2.25" budget boost, 31 bfg m/t KM2
BigJohn96ZJ is offline
post #10 of 22 Old 02-01-2013, 01:22 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
What is needed for a 5.2 -> 5.9 swap?
93-95 ZJ V8
5.9 flexplate
5.9 harmonic balancer
5.9 driver's side motor mount
torque converter from 96-98 V8
96-98 ZJ V8
5.9 flexplate
Notes
You can use a spacer or washers and make the 5.2 motor mount work.
You can oval out one of the holes on the 5.9 flexplate and make a 93-95 torque converter work.
Late '95 ZJs may not need the torque converter because some of them came with '96 flexplate and torque converter.
A complete motor from a 98 5.9 ZJ will bolt right into a 96-98 V8 ZJ. Because of OBD1 and EGR, it will not bolt into a 93-95 ZJ. You will need to use the old throttle body and sensors. If you have emissions testing, you will need to use the old intake manifold and the passenger's side exhaust manifold to maintain the EGR system.
The upside to swapping a 5.9 into a 93-95 V8 ZJ is the 46RH transmission, which is stronger than the 44RE used in the 96-98s.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #11 of 22 Old 02-01-2013, 01:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
Technically the 249 and the d44a in the 98 5.9 were better/stronger, not that I've seen a difference. The trans in the 5.9 is a different model than the others.
kg6mov is online now
post #12 of 22 Old 02-01-2013, 01:41 PM Thread Starter
gerardines
1990 XJ Cherokee
The vehicle it's a 1997 Grand Cheroke limited made in Venezuela, so it came with d44 in the rear.
post #13 of 22 Old 02-01-2013, 01:48 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you would need to bore the cylinders .090" over and throw in a 5.9 crank(which are external balance by the way) the absolute maximum you can bore one of these over is .060, so you can't get it to a true 360 cubes.
if you're going to stroke it you should just go with a 390 kit.
ratmonkey is offline
post #14 of 22 Old 02-01-2013, 03:17 PM
Rich93ZJ
It would be cheaper to buy a used niner
Rich93ZJ is offline
post #15 of 22 Old 02-01-2013, 04:54 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
http://www.precisionengine.com/rebui...nes/index.html
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
