So i need new shocks, my sway bar link broke... im looking at going up another 1 1/2 in soon... but need shocks, and sway bar link now.. can i put the sway bar links that are for 4 inch and up on, as well as shocks that are 4-5 inch of lift with out a problem..?
Just a thought... While adding the shocks and sway bar links now, why don't you also add spring spacers to get the height right. Then later on replace the spacers with 4-1/2" springs?
i ran 2in shocks on 4in of lift for a while, it was fine unless i hit a large bump (speedbump at 20ish or something) it would bottom out the shocks and sound like the world was going to end
well i should not have a problem bottoming out, as im prob running the opposite of u, larger shocsk than the lift...
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
