Can I remove the front or rear driveshaft to make my AWD jeep to 2WD? - JeepForum.com
post #1 of 40 Old 04-01-2011, 08:52 PM Thread Starter
Brentllongpre
I have a 4x4 97 jeep grand cherokee and I was wondering since the price of gas is so high if i could remove the front or rear drive shaft to make my jeep more fuel efficent. Will this damage my transfer case? or any other part? I can not switch between 4wd and 2wd its always 4wd.
Thanks for any help!
Brentllongpre is offline
post #2 of 40 Old 04-01-2011, 09:06 PM
PlatinumNiner
Pull the front shaft it's perfectly safe.
PlatinumNiner is offline
post #3 of 40 Old 04-01-2011, 09:27 PM
Technohead
But the real answer is no. Removing the driveshaft will not make a measureable difference in mileage. If mileage is a concern then you are driving the wrong vehicle.
-Eric
Technohead is offline
post #4 of 40 Old 04-01-2011, 09:29 PM
Candymancan
Best thing you can do for gas mileage is a complete tuneup and air filter replacement
Candymancan is offline
post #5 of 40 Old 04-01-2011, 09:31 PM
PlatinumNiner
Agreed on the marginal MPG gains but either way it is safe to remove the shaft. Every little bit counts.
post #6 of 40 Old 04-01-2011, 09:35 PM
Candymancan
I think someone did some kind of test, between 2WD and 4WD, and he drove like 500 miles each time. The 2WD yeilded like .6MPG more then the 4WD. This could however be something as simple that he drove a little diff while testing as that margin is a small difference to say for sure that it really gives you better gas mileage.
People on here are pretty religious when it comes to this and think 2WD doesnt make any diff, i personally beg to differ, with our 4.0 in 2WD vs 4WD even my mom notices there is a gas mileage difference and she knows nothing about Jeeps.
I have heared with a 97 and up 249 you can remove the DS and not worry abut frying your VC, its just the older Jeeps that cant do it because the TC doesnt lock when your parked so the Jeep will roll. But you wont have this problem
post #7 of 40 Old 04-01-2011, 09:38 PM
PlatinumNiner
Yes 1993-1995 you can not remove the front shaft. 1996-1998 it's perfectly safe. You do gain quite a bit of performance with no front shaft that i know from my own experience.
post #8 of 40 Old 04-01-2011, 09:42 PM
freakinheep89
a 242 will always get better mileage in 2wd because it actually stops sending power to the front shaft. this is not the case on a 249.
i agree with platinum niner that it does give a gain in performance with the shaft out, i drove around for a week while i was having my shaft shortened and it was a little more sporty.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #9 of 40 Old 04-01-2011, 09:43 PM Thread Starter
Brentllongpre
Thanks for all the replys so fast, im gonna try it out and see for myself if there is a difference. I was more concerned if it was safe or not, beings it is ok to do, i will try it.
post #10 of 40 Old 04-02-2011, 12:48 AM
Pugulis
If you do this, make sure you plug up the shaft holes. If you don't you'll get all kinds of crap inside the diff and transfer cases.
Pugulis is offline
post #11 of 40 Old 04-02-2011, 07:33 AM
newfieZJ
I ran w/o a front D/S last summer . No difference . Not worth the effort unless your VC is failing .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #12 of 40 Old 04-02-2011, 11:51 AM
ZJ_This
Ok i have to remove my d/s, vcu i completly locked. Can someone break it down how to do it. is it just the 4 bolt on the t/c side and thats it or is there more?
2011 Grand Cherokee Overland: All stock for now...
ZJ_This is offline
post #13 of 40 Old 04-02-2011, 01:09 PM
rdrbssr11
four bolts per each end of drive shaft. very easy to remove.
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #14 of 40 Old 04-02-2011, 07:36 PM
tcar
Total waste of time...
You're still turning the front axles and differential, turned by the wheels, not the case.
You will not notice ANY change in gas mileage.
That's why the x-fer case w/ a 2WD option doesn't get better mileage.
When gas prices get high people crawl out of the weeds with flakey ideas to save gas...
You'll be better off adding a couple pounds of air to your tires than doing that.
BTW, this is not safe on a 93-95 w/ quadratrac.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #15 of 40 Old 04-02-2011, 07:45 PM
Candymancan
If you have a front CV drive shaft, then you have to remove the 4 bolts at the trans fercase U joint end and i believe you also need to remove 6 bolts on the CV end of the drive shaft. Someone correct me if im wrong ?
Because i know my 5.9 front shaft has a round flat end on the differential with a CV boot and 6 bolts
Why did removing the front driveshaft make MPG go crazy? Tbirdbassist ZJ Grand Cherokee Forum 8 08-02-2009 12:53 PM
how to remove the front driveshaft greasable dustcap? knl ZJ Grand Cherokee Forum 1 04-24-2008 09:30 PM
How to remove the front driveshaft? JFox21 ZJ Grand Cherokee Forum 10 04-10-2008 04:02 AM
98 ZJ w/locked up 249 TC: Going to remove front driveshaft shudog ZJ Grand Cherokee Forum 10 04-15-2007 08:08 PM
Remove front driveshaft to save gas dwills898 ZJ Grand Cherokee Forum 29 08-14-2006 09:54 PM
