can i mix 5w-30 and 5w-20 safely? - JeepForum.com
post #1 of 33 Old 09-16-2008, 08:13 PM Thread Starter
mailforjon
mailforjon's Avatar
2005 WK
so i just changed my oil and now realized that i bought 1 gallon (4qts) of 5W-30 and 2 qts of 5w-20 by mistake.
i was entering the change in my maintenance log and realized on the receipt that the two quarts were different.
is this a problem if i plan on driving 900 miles tomorrow?
im such a bonehead.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #2 of 33 Old 09-16-2008, 08:15 PM
Darthteddy
1955 M-38
Dunno on the 4.7. . . If It was the 4.0, Id say just throw it in there. They will eat anything.
Ive done it in the past with other motors and never had any problems. . . Others may say different tho.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #3 of 33 Old 09-16-2008, 08:19 PM
Windowsrookie
Stick with 5W-30 in the 4.7
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #4 of 33 Old 09-16-2008, 08:20 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
im such a bonehead.
If it were me, I wouldn't give it a second thought, especially with the cooler weather.
Look at it this way, you now have 5W-26.6 in there.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #5 of 33 Old 09-16-2008, 08:23 PM Thread Starter
mailforjon
mailforjon's Avatar
2005 WK
no foolin. that was my intention but i somehow grabbed 2 qts of 5dubya-20 on accident.
thanks for all the responses. it usually takes me 4 months to get to even 3k miles so i should be well into the new england winter on this new "blend".
edit: found the following site, which is very informative
http://micapeak.com/info/oiled.html
-1993 XJ 2.5 [SOLD]
post #6 of 33 Old 09-16-2008, 08:32 PM
freeburg
1987 MJ Comanche
it'll be fine lol my MJ has a quart of reg oil in with synthetic she burns a lil oil and well i only had reg oil
87 MJ 2.5 5spd 6.5" 34"TSL D30/8.8 4.88's
D44/9in(spool)5.13s redoing then putting back on the comanche maybe....
freeburg is offline
post #7 of 33 Old 09-16-2008, 09:21 PM
RedEagle
Junior Member
Can You?? It seems you already have!
Should you?? No you should not!!!!
Mixing 5w/30 oil with 5w/20 oil and running it in a 4.7 engine that was built for a 30w oil is not a good idea!
Your engine was built with tolerances to be lubricated a 30w oil, not a 20w oil. This may seem to be a small difference but it is not!!
I'll assume your engine is not new and has some miles on it, going up in oil weight to a high-mile 40w oil might be OK but going down to a 20w oil is a very bad idea! Change it out to the right oil weight.
RedEagle is offline
post #8 of 33 Old 09-16-2008, 09:25 PM
PILL
Is risking damage to your engine really worth the 25$ it will take to change the oil to something that is recommended?
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline
post #9 of 33 Old 09-16-2008, 09:36 PM
elmer_fud
the 5w part is how much thick the oil is in the winter, and when it is cold
the 20 and 30 parts are how thick the oil is when it is hot.
I am not advising for or against this, I am just trying to give you accurate information.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #10 of 33 Old 09-16-2008, 09:51 PM Thread Starter
mailforjon
mailforjon's Avatar
2005 WK
it was my understanding (and as a previous poster alluded to) that as long as the specific type of oil was the same (in this case, valvoline maxlife), you can mix oils of any viscosity and the result will be something in between, but the result is not a linear proportion. Oil viscosity changes on a logarithmic scale, so calculating the result becomes very complex depending on the volumes of each type added.
i would venture to guess that with 2/3 5w-30 and 1/3 5w-20, that the net result would be somewhere in the high 20s. any mathematicians out there?
-1993 XJ 2.5 [SOLD]
post #11 of 33 Old 09-16-2008, 09:58 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
drain a little and put some 5w-40 in there?
My engine warranty requires 10w-40 the first 10k miles.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #12 of 33 Old 09-16-2008, 10:01 PM Thread Starter
mailforjon
mailforjon's Avatar
2005 WK
i wish my engine was under warranty and it had less than 10k on it.
ive been reading on forums for other makes/models and the general consensus seems to be that as long as the brands/types are the same and the weights are similar, there shouldnt be an issue.
-1993 XJ 2.5 [SOLD]
post #13 of 33 Old 09-16-2008, 10:07 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Do you wish you still owed someone $3500 for it?
I think Im going to royal purple my next oil change at 10k.
For your situation though, its not optimal, but I honestly dont think it would hurt anything
post #14 of 33 Old 09-16-2008, 10:20 PM
UofOJeeper
OP,
You don't have anything to worry about. While 5w-30 is the idea engine oil, running partial 5w-20 will not damage anything.
RedEagle is overreacting some. 5w-20 will be slightly thinner then 30 but not to the point of damaging anything. At the very worse, it might allow some oil to escape beyond the rings resulting in some burn off.
Some of you who are interested in learning more about oil would really enjoy www.bitog.com (Bob is the oil guy.com) and find it very educational.
Don't worry about changing your oil before your trip, just make sure you put 5w-30 back in on your next change.
1998 Laredo Special Edition V8
Toyo Open Country A/Ts - 245/70/R16
242 Swap
"A man who asks no questions, rarely has any answers"
UofOJeeper is offline
post #15 of 33 Old 09-16-2008, 10:23 PM Thread Starter
mailforjon
mailforjon's Avatar
2005 WK
thats not a bad payoff considering it only has 10k on it.
i was looking at financing about 15k for a WK w/ 18k on it.
-1993 XJ 2.5 [SOLD]
How to safely test the ESP system coyote runner WK Grand Cherokee & XK Commander Forum 13 11-04-2007 08:10 PM
