#1 | |
Headed Out West
Can I Get The Oil Pan Off?
Anyone with a 6" lift or lower remove the oil pan without discoing the exhaust from the manifold? It seems i should be able to if i remove the trackbar,draglink,& swaybar. Looks like a tight fit and i don't want to snag the pickup tube either.
My tranny is out at the moment and am changing the rear main along with pump and new gasket.
Jeff |
#2 |
Location: Vancouver, British Columbia, British Columbia
I would just pull the two motor mount bolts and hoist the engine up instead of removing all that other stuff but IDK maybe you'll have to do all that too.
- Russ 5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof |
#3 |
Headed Out West
Nah lol, i can remove all the other stuff pretty easily.
Jeff |
#4 |
im curious as well.
- John - 22 and learning <-- ORIGINAL -Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff RIP Troy Edwards
#5 |
nvm
10 char Last edited by bostonjeeper; 02-24-2010 at 05:01 AM.. Reason: thought you were wj |
#6 | |
i pulled the oil pan on my 4.0 just removing the tracbar when i dented it....... patience..... long extenders for your ratchet........ thats on my 4.0 wj with a 4'' lift, not sure about the 5 2
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::4'' IRO LA::32'' Retreads::IRO T case skid::KOR Light Bar & Tie Rod:: ::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Go Berzerk Winch Bumper::Smittybilt XRC8:: Quote:
#7 |
Headed Out West
I'll find out here shortly...
Jeff |
#8 |
Headed Out West
Nope. Cannot be removed without dropping the exhaust on the 5.2 Although removing the above mentioned items allowed more pan bolt clearance. This was almost as much fun as the CPS on my stocker which i am going to change as well. I can just crawl under the Jeep and look right at it...10 minute job.
Jeff |
