can i do a quick fix or do i need a new front shaft? - JeepForum.com
post #1 of 19 Old 08-30-2012, 05:55 PM Thread Starter
970001zj
its a 1997 v8 249 t/c orvis model and today i did some wheeling today and just at the crest of a hill i heard a pop then my rear tires dug down
so i did some thing to the front shaft , it moves around this area in a circle could reconnect it or do i need to replace
i will check this often as its my daily driver and im not a 4/awd pro.
DSCF4643 - Copy.jpg   DSCF4644 - Copy.jpg   DSCF4646 - Copy.jpg   DSCF4648 - Copy.jpg
970001zj is offline
post #2 of 19 Old 08-30-2012, 06:20 PM
WhiteOut
WhiteOut's Avatar
Its FUBAR, might as well swap in a U-joint shaft while you have the chance.
WhiteOut is offline
post #3 of 19 Old 08-30-2012, 06:24 PM Thread Starter
970001zj
i was thinking that too
dang
im trying to get aholdof the p.o.to make sure it a 97 t/c so i can just take it out for a while
thanks for your input
970001zj is offline
post #4 of 19 Old 08-30-2012, 06:32 PM
WhiteOut
WhiteOut's Avatar
Date of manufacture is on the transfer case.
WhiteOut is offline
post #5 of 19 Old 08-30-2012, 06:34 PM Thread Starter
970001zj
sweet good looking out im gonna check it right now
970001zj is offline
post #6 of 19 Old 08-30-2012, 06:58 PM Thread Starter
970001zj
i think it says 96
that means its a 97 model year right?
970001zj is offline
post #7 of 19 Old 08-30-2012, 06:59 PM
Snap-on
is everything inside still ok? or did something brake sometimes they snap out of place but can be put back together fairly easy, there should be a gear and a roller ball for each hole inside the metal case
Snap-on is offline
post #8 of 19 Old 08-30-2012, 07:04 PM Thread Starter
970001zj
havent got that far yet
will reply
970001zj is offline
post #9 of 19 Old 08-30-2012, 07:08 PM
Snap-on
http://www.ebay.com/itm/Jeep-ZJ-Gran...#ht_500wt_1054
They are not that expensive just be aware that the inline 6 and v8 have different lenghts
Snap-on is offline
post #10 of 19 Old 08-30-2012, 07:12 PM
iser
is the cv joint making a clicking sound yet? bc once it starts clicking, it's done. if it hasn't started clicking yet, then you can just rewrap the boot. that's what i did with one of my cv axles. if it is clicking, get yourself this thing like i did:
i know you are just using it as a dd, but if you ever lift it, that front driveshaft WILL break before you leave the parking lot. mine did.
also, got mine for free at a junkyard. imo, junkyards are best places to get parts for zj. going back tomorrow to pull a rear driveshaft.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #11 of 19 Old 08-30-2012, 08:49 PM Thread Starter
970001zj
took out the shaft
promptly did a burnout
970001zj is offline
post #12 of 19 Old 08-30-2012, 08:52 PM
iser
ahahaa, i did the same thing
iser is offline
post #13 of 19 Old 08-30-2012, 09:59 PM Thread Starter
970001zj
thats exactly what happened
970001zj is offline
post #14 of 19 Old 08-30-2012, 10:01 PM Thread Starter
970001zj
nope im going to rewrap it
970001zj is offline
post #15 of 19 Old 09-13-2012, 08:00 AM Thread Starter
970001zj
so im trying to fix my front drive shaft and im having problems
i put the bearings back in place but it will not go back together
is there a thread to help me with this repair?
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
front drive shaft damage , help needed
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 10:53 AM
Quick Front Drive Shaft question.. Mont ZJ Grand Cherokee Forum 0 01-02-2011 05:39 PM
Quick Quick Quick....Front DS U Joint Removal Darthteddy ZJ Grand Cherokee Forum 3 08-11-2008 01:25 AM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 10:17 PM
whole front axle shaft or just outer shaft? askoop ZJ Grand Cherokee Forum 6 06-24-2007 08:57 AM
