Can I change from U-joint style front axle shaft to CV-style??
#1 | |
Where are my damn keys?
Just what it says. Any advice on changing from the U-joint style front axle shafts I currently have to the constant velocity style? From what I've been finding online the CV style are much less expensive.
Any special tips or tricks I need to know if I decide to do this. I'm getting a low speed knock sound that I think I've narrowed down to a bad u-joint, so I'm thinking about doing new axle shafts (either u-joity or CV), new bubs.berarings, and new brakes. All at the same time. Figure at about 150K, these would be good preventative items. Thanks in advance!!!
No need to check your rear view mirrors, Chuck Norris will always be there. 98 Grand Cherokee Laredo Selec-Trac 4WD & the Mighty 4.0 Inline 6 Sold in 2008, I'm currently Jeepless!! |
#2 |
any zj shaft will work, and instalation of the u- joint shafts is the same as the cv shafts.
soak the hub to nuckle bolts with PB. there are 3 per side. and make sure you have something that will give you enough leverage to break loose the outside 36mm nut.
1993 Jeep ZJ. 4.0 |
#3 |
Are the CV shafts as strong as a U-Joint?
#4 |
from what ive heard, no. but for moderate wheeling they will take whatever you throw at them.
1993 Jeep ZJ. 4.0 |
#5 | |
My 05 TJ |
#6 |
Mr. Hyde!
CV Joints are stronger then u-joints of comparable size until you turn a CV joint, then it becomes weaker.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#7 | ||
zj tractor
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#8 |
Mr. Hyde!
Can replace U-joints (are servicable) and more often then not, you have wheels turned when the joint will break.
#9 | |
My 05 TJ |
#10 |
Mr. Hyde!
Just a note, quite often when a u-joint goes out in an axle shaft for instance, it'll blow the ears off of one of the half axles and make replacement impossible.
#11 | |
I've ordered my parts. New CV style axle shafts for both sides, new hub/bearings assemblies, new ceramic pads, and new rotors. Besides the 36mm socket, any other special tools or lubes I need to have on hand?? ![]()
#12 |
nope, your set. grease your caliper pins and if you want you can put antisqueal on the back of the pads.
1993 Jeep ZJ. 4.0 |
#13 | |
1998 ZJ Jeep Grand Cherokee Limited I6 Lifted LA 7", Goodyear MTR's 33", Winch, Bumpers, Sliderz, 4.10, Locked, and Loaded. |
#14 | |
Mr. Hyde!
#15 | |
Almost nobody wheels their ZJ/WJ hard on this forum to blow the ears off. We yet to see any broket u-joint on this forum. I'm not even talking about 760x, there is yet to be a thread about broken 297x or even 260x. Broken CV shafts, well I don't have to tell you guys, you see those threads every week |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
