can an exhaust leak cause a misfire? - JeepForum.com
post #1 of 4 Old 06-02-2009, 09:59 PM Thread Starter
MEinSoCal
CEL came on, and code P0302 showed up -- misfire cylinder #2. i'm aware i do have a crack in my exhaust manifold/header. so i was wondering, could that be the cause of the misfire?
before you suggest, swapping out spark plugs, i've already tried that... twice
MEinSoCal is offline
post #2 of 4 Old 06-03-2009, 12:21 AM
doggboy
While it is theoretically plausible, I would highly doubt it. What motor do you have? If it is the 4.7 check the coil (there is one on top of each plug), that could easily cause the problem. If it is the 4.slow check your plug wires, replace or swap the one giving you problems and see what happens. I don't know the missfire code, so it could be alot of things if that would include clogged injectors and such, but off hand the spark would be where I would start.
doggboy is offline
post #3 of 4 Old 06-03-2009, 03:55 AM
dobe
Yes it can.
dobe is offline
post #4 of 4 Old 06-03-2009, 04:47 AM
kentman
kentman's Avatar
2006 XK Commander
I never got any misfires with my cracked header on my old 4.0L ZJ. I drove it for quite a while with the crack. The misfire is more likely spark or fuel issues. I would change that plug first. If that does not make it go away, then I would change the fuel injector. My money is on the injector.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
4.7L exhaust leak rocks00tj WK Grand Cherokee & XK Commander Forum 6 11-17-2014 10:25 AM
Exhaust Leak... krakatoa24 ZJ Grand Cherokee Forum 3 07-24-2009 07:00 PM
exhaust manifold leak???? dinoriggin ZJ Grand Cherokee Forum 3 12-01-2006 01:17 PM
exhaust leak? TheAngus ZJ Grand Cherokee Forum 6 11-20-2006 09:49 AM
Exhaust manifold leak ? weaksauce ZJ Grand Cherokee Forum 3 03-29-2006 04:39 PM
