cam bolt q - JeepForum.com
post #1 of 14 Old 08-23-2011, 03:05 PM Thread Starter
Darman
cam bolt q
if i have adj lower control arms on a 95 Zj do i need the cam bolts? i read a thread on here that said if you have adj lowers you dont need the cam bolt or cam washer, a normal grade 8 bolt and washer will do.can anyone verify? thanks
Darman is offline
post #2 of 14 Old 08-23-2011, 03:07 PM
speedbucket
i never had a cam bolt on my 93, just a big *** nut and bolt. what lift are you installing?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #3 of 14 Old 08-23-2011, 03:39 PM
Technohead
You don't need the cam bolt but its alot easier to tweak the caster angle if you have one. Chances are, an alignment shop will charge you alot more if they have to start screwing around adjusting control arms.
-Eric
Technohead is offline
post #4 of 14 Old 08-23-2011, 03:45 PM
ajmorell
ajmorell's Avatar
No you don't. If you understand how to adjust them, and you can get an alignment shop to tell you what your caster angle is you can adjust the upper or lower CA's appropriately to get it where you need it.
ajmorell is offline
post #5 of 14 Old 08-23-2011, 03:52 PM
speedbucket
also,your pinion angle should determine your caster after you lift it, if you take it to get it aligned they may try to set you to factory specs which are bad for your pinion bearings after your driveline angles change from being lifted
post #6 of 14 Old 08-23-2011, 04:11 PM
ajmorell
ajmorell's Avatar
There needs to be some compromise between pinion angle and caster. If you set it only for optimal pinion angle you will likely end up with caster numbers way out of spec and your jeep will wander all over the road. If you set it for optimal caster you're going to get vibes like crazy from the front driveshaft. You'll probably have to split the difference. If you can maintain caster around 5* you should be golden.
ajmorell is offline
post #7 of 14 Old 08-23-2011, 04:19 PM Thread Starter
Darman
i destroyed the passenger side bolt getting it off, but i still have the cam washer. will this work? cam washer on one side with a normal washer on the other and a gr 8 bolt?
i have the cam bolt and washer installed on the drivers side with my new lower control arm and aligned it like it was before.
this stuff is way above my head.. never tried to figure it out.
Darman is offline
post #8 of 14 Old 08-23-2011, 08:20 PM
Technohead
You don't need to have an alignment shop measure the caster angle. It can easily be done with an angle finder. Either way, unless you get lucky its something of a trial and error process when dealing with adjustable control arms. . . measure, unbolt, adjust, bolt back together, measure again, repeat. If you are within a few degrees to start with then its much simpler to tweak with the cam bolts.
-Eric
post #9 of 14 Old 08-23-2011, 09:33 PM Thread Starter
Darman
so im trying to understand exactly how you would set the camber or how it works in a car. so lets say to get positive camber(which you want?) your essentially rotating the axle more towards the front of the car(counter clockwise if looking at driver wheel) so that the upper ball joint is forward of the rear ball joint and the steering pivot is more forward?
or am i way off base?
Darman is offline
post #10 of 14 Old 08-24-2011, 06:36 AM
Technohead
You mean caster not camber. You can't adjust camber on a solid axle (except for special ball joints which are stupid).
Generally speaking you want positive caster which means the line passing from the lower to upper ball joint points to the rear of the vehicle. Factory spec is about 7* positive. I find that 4* works pretty good. Keep in mind that the larger the caster angle the more likely you will get death wobble.
-Eric
post #11 of 14 Old 08-24-2011, 11:12 AM Thread Starter
Darman
yes your right. i mean caster not camber. but is taht essentially what your doing with the cam bolts, just on a much smaller scale?
Darman is offline
post #12 of 14 Old 08-24-2011, 12:55 PM Thread Starter
Darman
ok so just to confuse everyone and myself. this whole time i ment eccentric cam bolt. are they the same thing?
QUOTE=speedbucket;12066892]also,your pinion angle should determine your caster after you lift it, if you take it to get it aligned they may try to set you to factory specs which are bad for your pinion bearings after your driveline angles change from being lifted[/QUOTE]
My pinion angle is insane. Its probably a good 20 degress up. i used the measurements for my adj control arms that the instructions have and now my pinion yoke is pointed at my cross member pretty much
Darman is offline
post #13 of 14 Old 08-24-2011, 01:02 PM
speedbucket
FRONT
REAR
post #14 of 14 Old 08-24-2011, 01:42 PM Thread Starter
Darman
haha ok that helps alot! my front looks like that. is it the same weather its the cv style or u joint connection axle side?
Darman is offline
Easy question 95 GC,1 bolt or 2 bolt CPS? Curtiss-Jeep ZJ Grand Cherokee Forum 2 05-17-2010 01:02 AM
LCA bolt rustycherokee18 ZJ Grand Cherokee Forum 3 05-04-2007 10:11 PM
Bolt out? jeepnurse ZJ Grand Cherokee Forum 4 06-01-2006 09:35 PM
Sounds like bolt in the tire, but no bolt! DarkMesa8 ZJ Grand Cherokee Forum 10 05-16-2006 03:42 PM
Best way to get this bolt out? grovesj2 ZJ Grand Cherokee Forum 12 04-06-2006 08:35 PM
