Quantcast Calling all 5.9 owners. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Calling all 5.9 owners.
Old 03-22-2005, 07:20 PM   #1
BUNKER
I have a question about putting some new, most likely larger tires on my 5.9 and I'm in a bit of a dilema . If I put some bigger tires on my jeep, how much will this affect the awesome power of the 5.9 that I bought it for in the first place? I love the power of this vehicle but I just don't like the look of these stock tires on it. I'm not looking to put a lift kit or huge meats on it, just some slightly larger tires most likely bf goodrich all terrains. Also, what size can I go to just out of curiosity without having to lift it? Any help/pics/links would be greatly appreciated. Or just pics of your 5.9's in general just cuz they rock! Anyone of u guys that own this jeep know how nice it is to drive but I'm sure some of you have run into this situation before so please help a fellow 5.9er out. Thanks in advance guys/girls.
BUNKER is offline   Reply With Quote
Old 03-22-2005, 07:31 PM   #2
Evildriver-3
2 things to consider... tire size will effect your gear ratio, and the tire weight will effect your accel just as much as the tire size, just becareful some at's are extremely heavy tires
1995 Jeep gc ltd, 2005 Jeep gc ltd
Less than 8 is like playing with half a deck
]=Long Island Driveshaft=[
Evildriver-3 is offline   Reply With Quote
Old 03-22-2005, 08:07 PM   #3
CaliforniaJeep
My 30x9.5 BF Goodrich's on stock 15x7 wheels weight at 87lbs each
-Johnny-
~Updating~
CaliforniaJeep is offline   Reply With Quote
Old 03-22-2005, 08:27 PM   #4
Evildriver-3
-Johnny-
What was the weight of the original set-up? However i believe if i remember correctly the rule of thumb is 5.lbs added to a wheel is equivalent to 150.lbs on board, so lets say if you increased the weight on each wheel by 5.lbs it would be like adding 4 150.lb passengers to your ride everywhere you went.
Dunlops a/t version are heavy tires, i remember looking at them and thinking of giving them a try until my buddy rolled it over to me and i picked it up and thought i would need titanium wheels to offset the weight of those bricks...not to mention i didn't want to know what a titanium wheel costs
Old 03-22-2005, 09:24 PM   #5
5point9Limited
Hello fellow Niner! I faced the same dillema about a year ago when i purchased new shoes for mahnizzle'
I ended up opting for the BFG AT/KO 245-70-16. I absolutley LOVE the look and man does it make the 5.9 even more of a friggin Bear off the beatin' trai! As far as performance, I ran a 15.0 completly stock. I added the mods in my sig and ran a 14.6, with stock Goodyears. With the new setup, I am running a 15.2, so yes they will effect performance.
If you are counting 10th's of seconds, dont gettum' but if you want a nice friggin tire that looks real friggin good, then gettum! I would be more than happy to send you a pic tomorrow when it is light out. I can use my camera phone. I don't have the time nor patience to post pics on here (i have tried a million times with no success!) gimme your email address and i will send them asap.
My buddy is running the same exact setup on his slate niner and he likes it too. If I recall correctly, the Stock rim and tire combo weighs 56lbs and the BFG's bring it up to around 67lbs. The stock tires do make the 5.9 handle a little more nimbly. If you are worried about performance, maybe 235-70-16 instead of the 245 would work better.
Goodyear MT/R 245-75-16, Mopar PCM ECU, 52mm APS Throttle Body AND spacer, Flowmaster Exhaust, Homebrew K&N Intake, Summit 3" exhaust cutout, OME steering stabilizer, 2.25" B. Boost, ProComp MX-6 adjustable shocks,
Up-Country springs.
5point9Limited is offline   Reply With Quote
Old 03-22-2005, 09:59 PM   #6
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You can easily make up the performance lost by installing larger tires by adding headers, exhaust, and gears.
Hunter
PS. You don't want to even think about weighing the 33s on the steelies!
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 03-23-2005, 06:15 PM   #7
Evildriver-3
Yeah I wouldn't even think of adding a larger tire with steel wheels
Old 03-23-2005, 07:29 PM   #8
siderail88
I am new to this forum, and also have 1998 5.9. I am looking at adding a 2"BB and going to a larger tire and different wheel. I would like to see some pics of modified 5.9 models to give me some ideas. I wanted to go with a black steel wheel and 30x9.5 tires, but this sounds like it would be a bad idea.
siderail88 is offline   Reply With Quote
Old 03-23-2005, 07:37 PM   #9
Evildriver-3
Yeah adding any unsprung weight is a bad idea and worse for performance in all area's not just acceleration, but braking, and mpg also
Glock Forum
