Calipers Will Not Fit Over New Rotors - 1999 WJ - Page 2 - JeepForum.com
post #16 of 19 Old 08-29-2009, 01:57 AM
northpaw
I hope you are using a C-clamp as they said above, otherwise its not easy to press them back. But as I said, your caliper might be in need of renovation or change, since when the pistons get stuck, they will only get worse. Have you looked at the gasket around the pistons? Is it like charcoal, then your caliper have gotten warm cause the pistons have get stuck and the brakes has been on for quite a while and giving you warped rotors.
1999 Jeep Grand Cherokee LTD
4,7 Litre V8 Quadratrac II
4 Hella 320, 4 Boch Big Knick, JULA Roof rack, 245/75/16 General Grabber AT2, IRO 4 inch Lift kit
northpaw is offline
post #17 of 19 Old 08-29-2009, 07:25 AM
Turbonut
Undo the bleeder when compressing the piston(s) makes life easier and no need to bleed the brakes.
Turbonut is offline
post #18 of 19 Old 10-05-2009, 05:35 PM
iluvtruenos
I just unbolt the entire assembly, disconnect the line, close it off so it doesn't bleed brake fluid evreywhere, and put it in a vise.
Compresses it perfectly, and gives me time to flush all the fluid from inside the caliper. Refill with clean fluid, reattach, and rebleed. The entire process takes about 10 minutes for me now.
Before, compressing the pisons took half a freaking day.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #19 of 19 Old 10-05-2009, 11:21 PM
Airborne Lee
Airborne Lee's Avatar
I would never undo the bleeder and never undo the line unless I'm taking the caliper off.
JUST OPEN the cap on the reservoir and slowly press the pistons back with a clamp! You should use a shim to make the clamp cover the surface of the piston to give even pressure. I use my woodworking clamps because they are wide and give slow even pressure when I compress them with the hand lever.
'16 JKU Rubicon, Tan, RR Front Bumper, 9500i, Atlas Rear w/Tire Carrier M416 Trailer
Airborne Lee is offline
Replacement of Rotors, Breaks, Calipers: how many people have has issue with those? yukon0013 ZJ Grand Cherokee Forum 15 04-14-2009 02:26 AM
New Akebono calipers - do I need new rotors too? table ZJ Grand Cherokee Forum 2 10-13-2007 07:05 PM
Calipers grinding into Rotors sharky777 ZJ Grand Cherokee Forum 7 10-23-2006 06:39 AM
Feedback in Calipers and Rotors!!! marcoff ZJ Grand Cherokee Forum 1 05-09-2005 06:32 PM
Need your help: Removing Calipers from Rotors on 1999 Grand Cherokee 4x4, front cjdietzman ZJ Grand Cherokee Forum 4 07-01-2004 10:24 AM
